E Sully's Avatar
Deves Rings
What is the opinion on Deves rings?
My 1973.5 cis has 6 month only rings and from reading another post, if I could get them, Porsche wants well over $500.
Deves would be under $200. Can anyone recommend another brand?
Ed
1973.5 T
Old 10-09-2011, 02:22 PM
Ed, I wouldnt use Deves rings on anything, theyre way too hard and tear the cyl surfaces up.
Thats my opinion but its also what I ve seen.
What are the sizes you require to make a set?
Bruce
Old 10-09-2011, 04:01 PM
Is this the part: Pelican Parts - Product Information: OEM-91110390601
You should ring Pelican. What PET and the Pelican online catalog do not show
is that the rings can be ordered individually. If you have the individual part numbers
you may be able to order the rings through Pelican regardless of whether the
set part number is still available.
andy
Old 10-09-2011, 04:19 PM
E Sully's Avatar
The 73 cis rings are a tough one.
911-103-941-00-OEM
Porsche 911 Pistons, Cylinders, and Heads - Page 2
I've heard Deves were tough on cylinders, but wondered if with the steel cylinders it might not be an issue. Any suggestions?
Originally Posted by gibran911 View Post
Ordered rings from pelican two weeks ago as they were listed on the site.
Just found out from them that Porsche changed the part list #'s and now only sell them seperatly (each ring in a set of 3 per cylinder - individully)- so the price went from $230 to $540 for all 6 cylinders.
DEVES / PAECO Industries says that the can make a complete set (6 cylinders ) for about $160, but I need to send them a piston.
Ed
1973.5 T
Old 10-09-2011, 05:04 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Have you looked into Total Seal rings?
Or Hastings?
Bob
Bob Hutson
Old 10-09-2011, 09:16 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Pro Seal from JE.
Anything but Deves.............
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-09-2011, 09:21 PM
E Sully's Avatar
Total seal, Hastings, and Pro Seal do not seem to stock the middle 1.75mm ring.
Ed
1973.5 T
Old 10-10-2011, 07:03 AM
E Sully's Avatar
Evrything seems to have worked out. I found a vendor that had the correct Goetze rings. A little pricey at $250, but considering Porsche and all other vendors I contacted have none left in stock it is not bad.
Ed
1973.5 T
Old 06-20-2013, 11:14 AM
fred cook's Avatar
Deves rings.....
I used them once on a hopped up 2.6 Liter V-6 Capri engine. Of course, that is a cast iron block! The engine was pretty hot and it held together for a bit over 65K miles before I sold the car. Don't really know what happened to it later. While they worked well on my application, they are probably not what you want in your Porsche engine!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-20-2013, 03:10 PM
Goetze Rings Quality Issues
For what it is worth, I just purchased a set of Goetze rings for my 3.6 and had to reject them. End gaps were greater than spec, even though the cylinders are fine (still show original hone markings). Also, the thickness of the rings was greater than the OEM. They did fit in the ring grooves, but they were extremely snug (less than 0.02 mm clearance). I finally decided to bite the bullet and bought Porsche OEM at 3x the cost of the Goetze's. I had been warned about the Goetze quality issues, and I guess I learned the hard way.
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 06-20-2013, 07:49 PM
