DamonsCarrera's Avatar
901 airbox compatibility for various displacements
I'm not sure where is the best place to ask this question, so I'm going to ask it here.
Background: my car has a 2.4L motor, although it originally came with a 2.0L motor oh so long ago. I would like to find an airbox that is correct for my car as it came from the factory.
My question is: Would an airbox from a 2.0L motor fit on a 2.4L motor, or is there some issue (like for instance that the engine's stroke is longer so the carburettors are spaced just a little further apart) that prevents me from fitting an earlier airbox on the 2.4L motor?
-Damon
Old 07-09-2013, 06:02 PM
BURN-BROS's Avatar
Yes, a steel air box from 69-70.5 will fit. The engine dimensions did not change between most of the aircooled engines.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-10-2013, 08:21 AM
Aaron, I'm actually thinking of a plastic airbox, since that's what came on 914s. Thanks for your response..
Old 07-10-2013, 09:33 AM
While the air boxes might fit, the tubs that connect the intakes (carbs or FI) may not be entirely compatible.
Sherwood
Old 07-10-2013, 10:39 AM
BURN-BROS's Avatar
The later 71T had a plastic air box too, The hold down clamps may be the only issue you may have to deal with.
I have a customer that has one on his car. I will try to get some details for you.
Burnham Performance
Old 07-10-2013, 11:19 AM
I think I'd also have to get the parts that bolt to the carbs, then maybe the hold down clamps would match?
Old 07-10-2013, 12:37 PM
Sherwood, the tubes that connect the intakes? What tubes?
Old 07-10-2013, 12:38 PM
BURN-BROS's Avatar
I think he is talking about bases that bolt to the carbs, I have heard them called "boats" or "tubs"
If you can find the whole assembly then you are good to go.
The plastic carbureted air box I saw had cold start plumbing for the Zenith carburetors. I am not sure if the 914/6 ran a cold start with the Webers.
Burnham Performance
Old 07-10-2013, 01:14 PM
Aaron thanks for your help. Webers don't have cold start. So they are two different airboxes and I need to make sure I get the airbox for Webers?
Old 07-10-2013, 01:49 PM
BURN-BROS's Avatar
If Weber equipped cars did not run the cold start then yes. Since the 911's were Zenith equipped, then you would be trying to track down 914/6 Air box.
Now if you do not care about removing the cold start from the Air box then you have quite a bit easier time finding what you are looking for.
A lot of the cold start systems were removed long ago.
Burnham Performance
Old 07-10-2013, 01:56 PM
air boxes
My 914-6 does have the small grommets for the cold start system, though they were never offered on the Weber carbureted 914-6 2.0. I understand that the top of the 914-6 air box was also not as tall as that found in the 911s, but I think they all will fit in a 911
Old 07-10-2013, 08:00 PM
