Repaint of cylinder baffle tin ?
I'm repainting the tin from between my cylinders and I'm wondering if a regular acrylic enamel would do, or should I be using a "high heat" type paint for these?
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!) '11 Cayenne Manual, as in it has a clutch :-) (daily driver) '97 BMW Z3 (wife's ride) |
You will need a high heat paint. Regular paint will not last. Best option is powder coat but it's a little expensive.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Straight shooter
Powdercoat.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Why not buy new ones? I was surprised how cheap they are and come ready painted! Probably cheaper than getting existing ones coated!!
Yeah, powdercoat does seem like the best idea.
Thanks guys. keysham1, unfortunately I already bought these used ones (before I realized how cheap they are) to replace my rotted out ones.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!) '11 Cayenne Manual, as in it has a clutch :-) (daily driver) '97 BMW Z3 (wife's ride) Last edited by irobertson; 07-14-2013 at 12:34 PM.. Reason: added a line |
Powdercoat the engine tin at the same time.
Kinsley 1980 SC Targa - MS2, EDIS |
CTC has VHT ceramic spray paint which appears to be over kill for your application, being rated at 2000 degrees, so it should work.
Zinc plate?
Straight shooter
... won't protect as well as powdercoat. People seem to zinc plate everything else on these engines though so I imagine someone would endorse the idea.
Schleprock
Buying new will work for a while and then they'll rust like the used ones. I agree powdercoat would work just fine.
Or you could use a pure zinc galvanizing paint primer before high temp painting. I have used LPS zinc on exhaust parts and it works fantastico. http://www.lpslabs.com/product-details/613 Once you get some heat on the painted parts, it hardens to a very tough surface. I painted some header extension pipes with it and they withstood hard use on a track car. ![]() They're a little dirty in the picture but you can see the LPS paint lasted MUCH better than the crappy "ceramic" paint that Chinese OBX headers came with. I bought the headers new and the paint started coming off right away. I bought the extensions used, wire-wheeled them to remove most of the surface rust and painted with only LPS. Held up fantastic.
Kevin L '86 Carrera "Larry" |
It appears the ceramic paint on the headers next to the extensions has held up well? I'm not sure if the lower temperature further away from the manifold has anything to do with this or maybe the headers were not prepped as good as surface you created by wire-wheeling the extensions?
Schleprock
There's more pictures here
OBX Shorty Headers, Extensions, M&K Shorties You can see in one of the pictures the header collector is losing the paint too. Rust coming thru very easily. Definitely get what you pay for with the OBX plain steel headers. They fit/work OK but their painted finish is very temporary
DIY alternative...make new ones out of stainless steel!
I did mine that way....my lazyness got the better of me...never have to look at them again. Bob
Bob Hutson |
...and my blue mistress
I just used BBQ grill hi temp paint. Bead blasted them first and then sprayed them. Didn't feel like waiting for powder coat turn around time and you can't really see much of them when they are installed any way. Held up fine. I did powder coat all of my engine tin, fan shroud, etc. just didn't see the point on the air baffles.
Robbie 1976 Carrera3.0 1978 928 5spd |
Try not, Do or Do not
The truth is zinc works just fine. Over the years we've used zinc plating, powder coating, Duracoat and plain old Krylon with little difference to base a definitive answer on.
We zinc coat all of the tin as a base for the items we paint. Generally we Duracoat the tin on concours restorations (to simulate the factory finish) and on hot rod engines we leave the cooling tin gold zinc and powder coat the rest. Although Duracoat is expensive, as the name suggests, it's extremely durable and offer a genuine factory look for items like sheet metal, valve covers and throttle bodies. DuraCoat Firearm Finishes
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I went with Zinc. Was taking a bunch of fasteners anyway, and it's 1 price so I figured I might as well. I had the rest of the tins powder coated @ Calico.
![]() Todd
'81 SC |
Doc Speed
- Neil '67 911S (Ol' Ivory) '82 Hewlett Packard 34C |
I did an SL8 to G36 conversion in camo for a customer but that's a topic for another forum.
BTW: since is the NSA is watching, these are types of transmissions.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-21-2013 at 12:49 PM.. |
We media blast and powder coat. Been very happy with the results.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
The DuraCoat looks interesting.
I need to refinish my axles as well, so that sounds like a good option there too.
