j911brick's Avatar
Good for a laugh
New engine build project. I think somebody left it out in the backyard for about 10 years.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 08-10-2013, 05:05 PM
non-whiner
mreid's Avatar
cough, basketcase, cough...
"Too much is just enough."
Old 08-10-2013, 05:06 PM
j911brick's Avatar
My dad has an awesome set of tools...
james
Old 08-10-2013, 05:11 PM
non-whiner
mreid's Avatar
It's going to need more than tools.
It's going to need duct tape!
Old 08-10-2013, 05:13 PM
docrodg's Avatar
A little rubbing compound and some jb weld...
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 08-10-2013, 05:25 PM
j911brick's Avatar
it's going to need more than tools.
rotflmao!
james
Old 08-10-2013, 05:42 PM
I can Fix it - YouTube
Old 08-10-2013, 05:47 PM
safe's Avatar
I hope it was free, i think a better core will be cheaper than continuing with it. I don't think I would have bothered with rebuilding that.
Looks like it's been at the bottom of the sea, I don't think the aluminum would oxidize like that without salt.
Magnus
Old 08-11-2013, 01:01 AM
j911brick's Avatar
Its customer unit. He got a pretty good deal. Wants it rebuild cheaply and he has a good spare set of P/Cs. As long the crank is good its doable. Actually its doable anyway; for enough money. I suspect the CIS is going to cost a small fortune to fix.
james
Old 08-11-2013, 09:13 PM
MBAtarga's Avatar
Just send it to MM, for $3995 they will rebuild it with quality, used parts!
Mark
'83 SC Targa - since 5/5/2001
Old 08-13-2013, 06:54 PM
Bad LT
Uncle's Avatar
Ex Porsche Cup car with some boost and stuff.
Old 08-13-2013, 07:12 PM
Captain Annoying
SteamWolf's Avatar
Originally Posted by Uncle View Post
Oi! Get back to work
this time for sure...
Old 08-13-2013, 07:45 PM
Bad LT
Uncle's Avatar
LOL I am in a phone hook up. Clearly I am not listening.
Old 08-13-2013, 07:53 PM
Captain Annoying
SteamWolf's Avatar
Old 08-13-2013, 07:56 PM
j911brick's Avatar
Ain't nothing that funny!
james
Old 08-13-2013, 10:34 PM
j911brick's Avatar
More news. Two of the cylinders were frozen. SOme WD and heat got one loose. The other is more substantial so I'll let it soak longer. Maybe for a couple weeks. When I took the right side timing chain cover off I found a 13mm socket in there. The interesting thing is the socket looked like new, but it was a Craftsman from over 30 years ago. Apparently a mouse was living in the motor mount and started his own coin collection. I should check the dates.
The oldest coin is a 1955 penny, and the newest is a 1994 penny. My guess is the motor has been sitting since 1994.
james
Old 08-13-2013, 10:40 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We took apart an engine a few years ago that looked just like that. Our thought was that most of it was cosmetic, no big deal.
When we finally got the case split, we found that the water in the intake ports migrated past the rings and filled the case. Water being heavier than oil, it settled to the bottom and corroded the case around the sump opening to an unrepairable condition.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-14-2013, 07:18 AM
j911brick's Avatar
Yep, that is possible. I'm mostly worried about the crank.
james
Old 08-14-2013, 11:14 AM
The important parts of the crank (rod and main journals) are isolated from the possible contamination from the outside. There will likely be a patina of rust on the flyweights but that is superficial.
If you are referring to the chance that the crank was damaged before it was parked, I can't speak intelligently about that. I can only wish you "good luck".
Henry Schmidt
Ph: 760-728-3062
Old 08-14-2013, 02:36 PM
j911brick's Avatar
At least its not my money.
james
Old 08-14-2013, 04:22 PM
