It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
deck height and gaskets
If I do the deck height with the cam towers attached, how do I know if I have the right number of coppers under each cylinder jug to prevent leaks?
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 08-13-2013, 08:53 PM
The base gaskets are not intended to stop leaks they simply are used to correct or adjust for differences in height. Assuming that there is a flat contact surface between the base and the block.
How are you measuring deck height with the cam towers attached?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 08-13-2013, 09:32 PM
