Good for a laugh
New engine build project. I think somebody left it out in the backyard for about 10 years.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
non-whiner
cough, basketcase, cough...
"Too much is just enough." |
non-whiner
It's going to need more than tools.
It's going to need duct tape!
A little rubbing compound and some jb weld...
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
rotflmao!
I hope it was free, i think a better core will be cheaper than continuing with it. I don't think I would have bothered with rebuilding that.
Looks like it's been at the bottom of the sea, I don't think the aluminum would oxidize like that without salt.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. Last edited by safe; 08-11-2013 at 01:04 AM.. |
Its customer unit. He got a pretty good deal. Wants it rebuild cheaply and he has a good spare set of P/Cs. As long the crank is good its doable. Actually its doable anyway; for enough money. I suspect the CIS is going to cost a small fortune to fix.
Just send it to MM, for $3995 they will rebuild it with quality, used parts!
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Bad LT
Ex Porsche Cup car with some boost and stuff. |
Captain Annoying
this time for sure... |
Bad LT
LOL I am in a phone hook up. Clearly I am not listening.
Captain Annoying
Ain't nothing that funny!
More news. Two of the cylinders were frozen. SOme WD and heat got one loose. The other is more substantial so I'll let it soak longer. Maybe for a couple weeks. When I took the right side timing chain cover off I found a 13mm socket in there. The interesting thing is the socket looked like new, but it was a Craftsman from over 30 years ago. Apparently a mouse was living in the motor mount and started his own coin collection. I should check the dates.
The oldest coin is a 1955 penny, and the newest is a 1994 penny. My guess is the motor has been sitting since 1994.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast Last edited by j911brick; 08-13-2013 at 10:58 PM.. |
Try not, Do or Do not
We took apart an engine a few years ago that looked just like that. Our thought was that most of it was cosmetic, no big deal.
When we finally got the case split, we found that the water in the intake ports migrated past the rings and filled the case. Water being heavier than oil, it settled to the bottom and corroded the case around the sump opening to an unrepairable condition.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
The important parts of the crank (rod and main journals) are isolated from the possible contamination from the outside. There will likely be a patina of rust on the flyweights but that is superficial.
If you are referring to the chance that the crank was damaged before it was parked, I can't speak intelligently about that. I can only wish you "good luck".
