throttle bobys
Hi
what is the best way/option to go if i want to put individual throttle body's on my 911sc?
Old 08-19-2013, 08:07 AM
jsveb's Avatar
Search the forum ( itb) there are plenty to choose from.
Good luck
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 08-19-2013, 08:14 AM
Trophy's Avatar
"throttle bobys"
Are they the English version?
Lots of Options out there:
PMO
Jenvey
Hargett Precision
Other that make kits using mainly Jenvey ITB's"
Rothsport
9M
Steven
1995 - 993 RS Tribute - 4.0l Engine plus other stuff...
2005 - Touareg V8 Tow Vehicle
Old 08-19-2013, 08:19 AM
HeHe!
sorry i ment ''throttle body''
will have a look at above mentioned options and give an update
Old 08-19-2013, 12:01 PM
throttle bodys aint cheap! but so nice
Old 08-19-2013, 12:07 PM
Trophy's Avatar
Rothsport make a great setup that is designed for the 911 spec series which I believe is based on SC engines. The only problem they are very expensive and of course you also need an aftermarket ECU to make it all work.
Steven
Old 08-19-2013, 02:04 PM
2001 (or so) Suzuki GSX-R750 individual units. Set of 4 for $100. So need to buy 2 sets. 42mm inner diameter at throttle plate. Takes a bit of effort to convert but they are very cheap, very light, and very effective.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 08-19-2013, 04:25 PM
Will have a look at Rothsport and see what direction to go! I have a nice aftermarket ECU system,
So I am 1 step closer
Old 08-20-2013, 01:18 PM
Will also check out the GSXR ones out! Will give an update if I find something
Old 08-20-2013, 01:19 PM
Kartoffelkopf
Spenny_b's Avatar
Triumph Triple itb's ...less wastage, lol
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 08-20-2013, 01:35 PM
I find the perfect throttle body package! And it includes the ECU system and easy to install!
Will update with pic when I received it,TROPHY you will like it
Old 08-25-2013, 12:24 AM
jsveb's Avatar
Dzug???
Jesper
Carrera 3.0 1975
Old 08-25-2013, 08:02 AM
Trophy's Avatar
Do Tell....
Steven
Old 08-25-2013, 12:46 PM
Old 08-26-2013, 01:31 PM
Almost done!
Old 08-26-2013, 01:32 PM
Trophy's Avatar
That looks great, who makes it?
Steven
Old 08-26-2013, 01:35 PM
Yeah, come on- tell us something good!
'90C4
Old 08-26-2013, 08:55 PM
Will give all detail on everything soon,just want to fit filters and dyno
Old 08-26-2013, 09:21 PM
Jeff Alton's Avatar
We have used Jenvey and PMO.
Jenvey have a straight intake manifold, PMO uses a Weber style intake.
Jenvey a pain to balance, PMO easy as pie.
Jenvey requires some adaptation as they were designed for a cable throttle, but it is easy to configure a rod set up or spend $$$$ on the Rothsport linkage.
We seem to make more power with the Jenveys...
PMO have the classic weber look....
I have another set at the shop I will post pics of because I can't tell who made them. They are interesting but have a rather oddball linkage set up that will need some work. We plan to use them on a 2.8....
Cheers
www.turn3autosport.com
Old 08-27-2013, 06:03 PM
SchnellSchweitz's Avatar
Boy would I like to throttle these boobies.
Sorry... I just couldn't resist.
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 08-27-2013, 06:44 PM
