neilca's Avatar
Hypothetical engine question
Lets say I have racing engine that produces 200 hp at 10:1 compression on pump gas. How much of an increase in hp would be seen if I went to 12.5:1 and race gas. All other variables are constant.
Old 10-19-2013, 06:10 AM
non-whiner
mreid's Avatar
I'll play. About 5%, so 210hp, but you need a twin plug set up. So, machine your heads while you are replacing the p&c's.
"Too much is just enough."
Old 10-19-2013, 06:41 AM
Compression Ratio HP Determination Program
Old 10-19-2013, 07:16 AM
neilca's Avatar
Thanks Chris,
That calculator is awesome. It says 6%. Mark was dang close.
I also found this on anther site
" You might get 7% - 10% by going from 9:1 to 10:1, but it'll be less from 10:1 to 11:1, less yet from 11:1 to 12:1 and so on."
In my case that little bit is not worth chasing.
Old 10-19-2013, 07:32 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Remember...speed costs money....how fast do you want to spend?
LOL.
Bob
Bob Hutson
Old 10-19-2013, 11:15 AM
Try not, Do or Do not
Henry Schmidt's Avatar
These numbers were very well understood by Porsche race engineers back in the 60s-70s. That is one of the reasons why factory twin plug NA racing engines were all built with 10.4:1 as apposed to choosing higher ratios.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-19-2013, 11:55 AM
Nice calculator.... My question is how is the CR change effecting torque? I'm trying to decide between 10.5 and 11.6:1 wossners for my 95mm SC rally build.
Old 10-19-2013, 05:03 PM
PFM PFM is offline
PFM
PFM's Avatar
3literpwr,
You are correct to ask about TQ. The change in compression should be coupled with a cam change to optimize the power curve. If all things remain unchanged the TQ increases a bit more at peak TQ than other areas but in general go up in the same 5% range. A cam change can take more advantage of more compression. A larger cam benefits more from increased compression than a small cam does in the HP chase.
Stay Tuned,
PFM
Old 10-20-2013, 01:47 PM
Complex issue but increasing static compression does generally increase torque but will also increase peak cylinder temperature which can have an impact on detonation.
There is also a compromise with exhaust sizes and smaller exhausts tend to maximise the improvement in torque with increasing compression but can have a negative effect on the engines ability to rev and hence a negative impact on horsepower.
I would always choose Horsepower rather than Torque and select gear ratios accordingly.
It seems important to consider the entire power train before deciding on compression and looking at speeds in gears, maximum speed, tractive effort and max engine revs would all seem to have a part to play in the decision.
Old 10-21-2013, 02:04 AM
