tharbert's Avatar
Blue Sealant :(
I'm tearing down my engine for a rebuild/refresh. I cracked the case and found someone had been there before and resealed with blue silicone. Why the hell didn't they replace the O ring here?
Looking at the internals, they didn't appear to do anything while they were in there but slather goop around the edge. That said, the case halves weren't leaking. Had plenty coming from the heads.
Found STD bearings and a three rib pump.
I plan on replacing this with a mag 4 rib from Tom Butler (tom1394racing):
Case will be headed to Ollies once I remove the studs.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 09-18-2013, 08:53 AM
docrodg's Avatar
It is amazing what some do to an engine. MM did the one I am working on and used form-a-gasket all over the cam housings, which is a pain to clean off. Found pb blaster and a brush works well tho.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 09-18-2013, 10:43 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Blue silicone or Hylomar?
Kevin L
'86 Carrera "Larry"
Old 09-19-2013, 10:56 AM
ASE Master Tech - 35 yrs
larrym's Avatar
Arrow
X2
quite possibly Hylomar - which explains why the case was not leaking - a smart choice by the prior builder imho -
QUOTE=tharbert - I cracked the case and found someone had been there before and resealed with blue silicone. That said, the case halves weren't leaking.
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 09-21-2013, 07:27 PM
