Bench start / hot wire engine
I am tryng to bench start my 6 with carbs. I have fuel but no sparks.
I check the points and they are opening and closing. All grounds are connected. Positive is applied the positive side of the coil. The only thing I am not sure how to chck is the cd box. As far as I can tell the c box is powered from the positive side of the coil. help! |
The 3 prong CD gets power from the center of the 3 post plug in, 12 volt. The coil and the points are fed from the other outside white wires,
Bruce |
You have it a little backwards. The CDI is powered by the battery, and the CDI to the coil. It will hum when 12V is applied.
Ed 1973.5 T |
I understand a b and c is at the plug, what is d? I don't seem to have a d, the only extra plug I have is a ground from the harness
D is the ground tag on the bottom front as is the tag on the chain cover nut under the distributor. Your shield wire connects to the ground.
Bruce |
Thanks . I got it started. I didn't connect the ground on the Cdi box.
ASE Master Tech - 35 yrs
this is a re-post of same thread you started on another Tech forum - see the discussion there
914World.com - The fastest growing online 914 community! .
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
