| Registered Join Date: Feb 2009
				Media tumbling a mag case
			I'm getting ready to send Ollie's a mag 7R case. Is it worth having it tumbled? The alum case pictures show an almost polished finish which looks great. What can I expect tumbling a mag case? Will it turn to a light gray from the almost aged black look? Thanks guys Gary | ||
|  09-28-2013, 07:01 AM |
| Registered Join Date: May 2004 Location: Boulder, Colorado
			My understanding is that this is not only not worth it, it is a bad idea for a mag case.  The surface oxidation of the mag cases is, I think, even more problematic than it is for aluminum (where it forms a protective coating, doesn't it?).  After a while mag cases, or some parts of them, can look as if they had rusted and lost material.  Polishing this is just going to accelerate this, I think.  And if it changes color with polishing the surface, I believe it will quite quickly revert to what it was.
|  09-29-2013, 03:29 PM |
| AV8TOR Join Date: Mar 2009 Location: Colorado Springs
			Greetings Gary, I am in the pocess of restoring a 914-6 (#2463, a '70). I sent the little 2.0L magnesium case out to George and Ike at Ollie's to have it align bored and new oil pressure relief tap done. I could not decide If I needed the case tumbled in the media to clean it simply because the old mag cases just don't clean up like an aluminum case. I went ahead and had them tumble it ($120) as this car is going to be a "show" car. I got what I expected, nice and clean smooth surfaces, but not shiny and bright. The magnesium ages and turns darker as heat ages the case. The tumble only makes the finish "clean". Tom/AV8TOR Colorado Springs | ||
|  09-29-2013, 06:06 PM |
| Registered Join Date: May 2009 Location: O-H-I-O
			Ollie's tumbled my mag case -- no complaints.
				__________________ Landon - 1972 911T | ||
|  09-29-2013, 09:11 PM |
