totle's Avatar
carerra 3.2 with itb and motronic - possible
Hi,
Having a Euro 86' 3.2 that I'm going to rebuild. It will go into a 914-6 GT replica.
I will do small upgrades like 964 cams and steve wong chip.
Is it possible to run ITB's and original Motronic ECU?
Would I have to convert MAF to MAP in order to use the original Motronic?
Just thought of it as an cheaper option than going EFI.
Is this possible? Anyone that has done it?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 10-05-2013, 04:38 PM
sjf911's Avatar
I don't see how that is possible, MAF and MAP (speed density) are completely different calculations. MAF is a direct measurement of air mass while MAP has to be multiplied by RPM, volumetric efficiency, and corrected for temperature to estimate air mass.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 10-05-2013, 07:19 PM
Turbonut
Raceboy's Avatar
Also MAP don't work too well with ITB's, it can be made to drive quite ok, but Alpha-N+MAP compensation is really the only proper way to get it to have traffic driveability of a stock car+response of the bike.
I will be making an adapter harness for 3.2 for a friend during winter in order to use VEMS ECU on stock harness. An additional loom will be necessary (for WBo2, grounds at least), better yet for injectors also as stock is wired as a batch fire.
Stock trigger arrangement is fine with VEMS also.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 10-07-2013, 04:09 AM
