throttle bobys
Hi
what is the best way/option to go if i want to put individual throttle body's on my 911sc? |
Search the forum ( itb) there are plenty to choose from.
Good luck
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
"throttle bobys"
Are they the English version? Lots of Options out there: PMO Jenvey Hargett Precision Other that make kits using mainly Jenvey ITB's" Rothsport 9M
Steven 1995 - 993 RS Tribute - 4.0l Engine plus other stuff... 2005 - Touareg V8 Tow Vehicle |
HeHe!
sorry i ment ''throttle body'' will have a look at above mentioned options and give an update |
throttle bodys aint cheap! but so nice
Rothsport make a great setup that is designed for the 911 spec series which I believe is based on SC engines. The only problem they are very expensive and of course you also need an aftermarket ECU to make it all work.
2001 (or so) Suzuki GSX-R750 individual units. Set of 4 for $100. So need to buy 2 sets. 42mm inner diameter at throttle plate. Takes a bit of effort to convert but they are very cheap, very light, and very effective.
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
Will have a look at Rothsport and see what direction to go! I have a nice aftermarket ECU system,
So I am 1 step closer |
Will also check out the GSXR ones out! Will give an update if I find something
Kartoffelkopf
Triumph Triple itb's
...less wastage, lol
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
I find the perfect throttle body package! And it includes the ECU system and easy to install!
Will update with pic when I received it,TROPHY you will like it |
Dzug???
Do Tell....
Almost done!
That looks great, who makes it?
Yeah, come on- tell us something good!
'90C4 |
Will give all detail on everything soon,just want to fit filters and dyno
We have used Jenvey and PMO.
Jenvey have a straight intake manifold, PMO uses a Weber style intake. Jenvey a pain to balance, PMO easy as pie. Jenvey requires some adaptation as they were designed for a cable throttle, but it is easy to configure a rod set up or spend $$$$ on the Rothsport linkage. We seem to make more power with the Jenveys... PMO have the classic weber look.... I have another set at the shop I will post pics of because I can't tell who made them. They are interesting but have a rather oddball linkage set up that will need some work. We plan to use them on a 2.8.... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Boy would I like to throttle these boobies.
![]() ![]() Sorry... I just couldn't resist.
'82 SC 3.0L Targa, Chiffon/Brown “It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche |
