carrerarsr65
refinish valve cvrs.?
just sent my valve and chain case/cvrs. out to be blasted where these painted or treated with something? can i powder coat my chain cases? covers?
Old 11-06-2013, 06:52 AM
911 2.2 T targa
Originaly they were not coated. Yes you can powder coat them, but only on the outside and not on the sealing surfaces
Old 11-06-2013, 07:27 AM
Since these are aluminum pieces, wouldn't anodizing be the proper coating?
Old 11-08-2013, 07:49 PM
Straight shooter
Lapkritis's Avatar
Anodizing would be ideal but over-kill for most. I anodized my valve covers in milspec hard black.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 11-08-2013, 08:03 PM
irobertson's Avatar
I had my valve and chain housing covers powder coated, but didn't do chain housings themselves. I did them all in a semi-gloss black, then wet sanded the coating off the script and ribs and had them recoated in clear. I masked the area around the script with thin plastic from a bubble pack to protect the black from getting scuffed.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!)
'11 Cayenne Manual, as in it has a clutch :-) (daily driver)
'97 BMW Z3 (wife's ride)
Old 11-09-2013, 04:40 PM
