964 Oil pump in 3,0 case
Hello,
as the title says I want to install a 964 oil pump in a 3,0 case. But I just saw that the connection shaft does not fit to the oil pump. Would the 964 shaft fit to the 3,0 intermediate shaft? Thanks, Malte |
Everything fits but you need the shorter 930.107.143.03 part for the turbo and C-2.
Bruce |
Perfect, thank you for the fast answer!!!
What sump plate is used?
Sigurd 73.5T 3.2SS EFI X87 944S 3.0 |
You will need a dished sump plate to clear the screen on the 964 pump.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Try not, Do or Do not
I like this sump cover, designed and manufactured by Burnham Motorsports (Formally Rennwerks)
Aaron Burnham Burnham Performance 1071 Avenida Acaso ste.D Camarillo, Ca. 93012 805-240-6931 rennwerks@hotmail.com ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
