Engine Compression Numbers
The guys helping with the restoration of my 1970 911T have checked the engine compression numbers as follows:
1 - 90
2 - 90
3 - 90
4 - 130
5 - 90
6 - 90
With the following advice..
Scoping the bores shows cleaner edges to the piston tops meaning oil ring issues. the numbers say compression rings as well.
They recommend the motor needs a "Top-End" meaning, everything from the rings out (rings, valve guides, valves, rebuild carbs etc.)
I absolutely don't doubt this is what needs to be done (very well respected mechanic/engineers), however I would like to understand more about compression and what is involved in rebuilding the top end. I've done a search here but can anyone help with more info or suggest a link? I'm a newbie and here to learn.
Old 12-08-2013, 01:05 AM
Have your mechanic do a leak-down test to pinpoint where the leakage is. By listening, they should be able to tell if it is in the intake or exhaust valves or leaking past the rings.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 12-09-2013, 05:50 PM
