Gordo2's Avatar
Case cleaning and more case cleaning
I cleaned my case by pressure washing, soda blasting and re-pressure washing. Came out pretty clean, but not clean enough for my liking.
Tonight I mounted each case half to the engine stand for a detailed cleaning.
I cleaned the head stud threads using a homemade thread chaser made from 2 of the used dilvar head studs:
I also scraped out most of the old sealant where the case through bolts and perimeter bold pass (flat head screwdriver with sharp edges). This helped the case mating quite a bit - previously the case halves went together rather tight, and once together, they didn't want to separate again. There was quite a bit of sealant in outer edges of the perimeter holes.
Additionally, I cleaned up the through bolt holes and oil passages (HF sells a great engine cleaning brush kit for ~$15). I brushed, sprayed with carb cleaner and then punched a Kimwipe through the holes where I could. I found my bendable magnet worked as a great bore punch to push a Kimwipe through the holes; similar to this:
Lots of black stuff on the Kimwipes with first pass...
Finally, I rotated each case half 1/4 turn to to get a good view that allowed detailing inside and out. I wasn't too concerned with how the outside of the case looked - clean was the objective...
Case halves are clean and ready for my next step:
Enough for one night.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 12-08-2013, 09:45 PM
Looking good. Im going to have mine media tumbled then have all the oil passages R&R. I am debating on doing the caustic soda treatment before so that I can get that nice dark mag look. After a nice soak in an ultra sonic bath should do the trick. Love the home made tap, lol.
Old 12-09-2013, 05:54 AM
DSPTurtle's Avatar
I absolutely love how Porsche designed the case to be curvy and sexy.
Old 12-09-2013, 11:53 AM
Kartoffelkopf
Spenny_b's Avatar
Ha-hah!....er, okay!
OP - nice job. Quite cathartic, isn't it?
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 12-09-2013, 11:59 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
One of the "old tricks" was to de-flash the insides of cases.
When the cases are first molded or poured...the sections of the form...where they come together sometimes form a thin ridge or flash....these can break off during operation...so removal is necessary.
Other than that...polishing can help with oil flow back to the scavenge pump (smooth = faster flow).
Keep up the good work.
Bob
Bob Hutson
Old 12-09-2013, 12:02 PM
DSPTurtle's Avatar
Quote de DSPTurtle
Spenny, I'm serious!!! Do you see the curves? Someone with an artistic flair could get a gorgeous woman with a cute rear to lean over at the same angle and get the girl and the case to look amazing in a single pic.
Or maybe I have just spent too much time cleaning cases with qtips before I put them back together.
I really do think it's artistic. Hell, Ferry coulda just squared everything off and made it much cheaper to produce.
Old 12-09-2013, 04:15 PM
Gordo2's Avatar
I'm with you brother - I've seriously wanted to put some of my refinished Porsche parts on the fireplace mantle so I could admire them... artful, purposeful engineering.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 12-09-2013, 06:11 PM
KTL KTL is online now
Schleprock
KTL's Avatar
When you look at the case from a manufacturing/machining perspective, it's pretty amazing how much work goes into producing the end result. Pretty darn impressive design, given its age.
Kevin L
'86 Carrera "Larry"
Old 12-11-2013, 09:06 AM
Hi DSPTurtle,
I love the creativity and how elegantly and tastefully you described this. I see a an artistic (PG/PG13) poster in your future that you would sell to all of us. Do some rough sketches and present it to a photographer to bring it to life for you. Oh, and don't forget to add some RS racing stripes at the bottom and name it using the original RS/RSR text. Hmmmmm, T-shirts? Then for laughs, pose for one as a gift for your wife. Seriously, you're on to something.
Best,
dmark9
Old 12-11-2013, 02:06 PM
Straight shooter
Lapkritis's Avatar
Gordo
I thought about this a few times when I had my engine all freshly coated and waiting to lift back into the car. It would make a fine coffee table with a thick piece of glass atop the Weber trumpets. I've often considered an engine swap so it may become a reality for storage.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 12-11-2013, 03:08 PM
I intend rebuilding the engine later, but for now want to do some clean up in the engine bay. I have removed the alternator and fan which require bead blast, they are in very poor condition. Does anyone know what would be the factory finish for these items, i don't want to paint them.
Old 12-17-2013, 04:11 AM
