Tcrate's Avatar
rebuild hours for a 3.2L
Question: I have a 3.2 out of an 87 911. Need to replace one of the heads and while in there it appears the exhaust valve guides are sloppy. Basically got an estimate for 1 head replacement, new valve guides, valves, and piston ring replacement. labor came to about 48 hours. so that is pulling the camshafts, heads, removing pistons and putting it all back together. Is this amount of hours in the right ballpark? I would expect a whole engine rebuild to fall into that many hours. Thoughts?
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
1973 Mustang Mach 1 351C
Old 12-11-2013, 08:10 PM
DCPorscheFreak's Avatar
Send a message via AIM to DCPorscheFreak
My tech who has built several engines (including one for me) told me that the dis-assembly, reconditioning, and re-assembly of a 3.2 motor would be 46 hours total, all in.
That leaves me wondering like you that he's either not very good and/or trying to take you for a ride.
John Mackay
Current: '10 Boxster S "GrossMutter"
Previous: '04 R32, '86 Carrera coupe, '72 911E w/ 2.7 RS+, '73 914 2.0, and '70 911T targa
Old 12-13-2013, 07:04 PM
8 full hours a day for 6 days, doing nothing else?
Sounds like wine, roses and filet mignon when that engine is done...
Old 12-14-2013, 02:39 PM
AlfonsoR's Avatar
It could simply be that your tech is not that familiar and he plans on triple checking measurements. I would talk to him and find out why his hours seems a bit long.
If you're still not satisfied, go to someone else.
In the end, I would tend to err with someone who is going to take his time as opposed to someone who is going to slap parts together. Anyone could do that, i.e. Motomiester.
"Simplicity is supreme excellence" - James Watt
Old 12-17-2013, 10:17 PM
ASE Master Tech - 35 yrs
larrym's Avatar
as i recall the flat rate book says 40 hrs - that does not include anything more than remove measure & replace
911 sc rebuild estimate
- add in unknown extra or elective machine work (such as replacing guides) and the sky is the limit
i was recently quoted 15 hrs just to do a cam swap on a long block engine on a pallet by a local reputable 911 shop
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 01-12-2014, 07:47 PM
One thing people also tend to forget is that those times are based on when the motors were low mileage and new/clean. You can easily spend an additional 10-20 hours cleaning/inspecting parts properly if you want to do a good job and have a motor that lasts~
Old 01-14-2014, 07:51 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Agree with CK. The time I have spent on cleaning and checking is huge and my engine was quite clean to start with. The actual assembly part will take far less time and much more joy.
Old 01-14-2014, 01:27 PM
