2.0 Race Motor - Valve Size
I am in the process of changing the unknown cams in my 2.0 motor with 81mm JE 9.8:1 pistons to DC60/62 cams. Although the heads have been ported to 38mm, I have discovered that they have standard 2.0T valves in them. Would I be leaving enough on the table to justify the expense and hassle of putting in 45mm intake valves (if this is possible)? The plan is to run the motor to 7500rpm.
Rob |
Try not, Do or Do not
Converting a 39mm head (earliest 2.0) to 45 x 39 would be possible but very costly. Converting a 42mm head (42 I, 38 E) makes sense but requires a really competent machinist. I'm not sure changing the exhaust valve is necessary but 39 is the maximum. 45 X 39 is the maximum for these heads because the valve angle creates challenges (collision) with high duration cams.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thread Tools | |
Rate This Thread | |
