Deglazing Nikasils - my method
Busy 911 week for sure. After searching the Forum and reading up on the best way to deglaze Nikasils, I bought a pack of red Scotchbrite pads. I wanted to ensure there was even pressure and action on all areas of the cylinder so I wasn't big on the hand method. My bright idea was cutting the pads in long strips and stapling them to my conventional 3 arm hone. Using a variable speed cordless drill, some dish soap and a bit of water I went to work. It was not super fast but boy did it ever do a nice job. Now I better get that sink cleaned up!
Let's see finished product.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. |
At moment, I can't get the macro function working on my camera so the clarity is not good enough. I'll post one once I sort it out.
Dave |
Schleprock
I'm surprised nobody's tried an aluminum oxide flex hone like this with some honing oil
2014 Goodson Catalog Reason I say i'm surprised is because the red scotchbrite pads are aluminum oxide. I know the grape hone has been debated before and given a big thumbs down. But the dreaded grape hone in aluminum oxide is going to be basically the same "roughness" as the scotchbrite and it would be well lubricated with the honing oil
Kevin L '86 Carrera "Larry" |
Just a personal experience here, be careful what you use. I read mixed revoews on deglazing nikasil cylinder. I used red sb pads by hand and did not feel they worked well. I found a local engine builder with a good reputation and spoke with them. They said they had plenty of experience with nikasil coated cylinders, not to worry. When I got them back they looked great, except for the spots of porosity which were now showing. Only one cylinder was concerning. Ended up recoating all of them.
de-glazing nicasil cylinders - a new approach? |
Straight shooter
The ball/Flex hones come in different grits just like sand paper... too rough and you'll do more damage by scratching through and shredding the surface.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Air Medal or two
Here inethe lieth a problem..................
Some of the real experts that have been here for years and years get tired of re writing old post. Most of us hate to look in the search machine (never seem to work well ) But, much has been said by real experts as far as honing a niky cylinders. In most cases you will do more harm then good. Last i knew warm soapy water and a little scotch brite by hand was they key.On top of that the color was important too,,,- green or red, cant remember
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Schleprock
Red with HOT soapy water is the current method I use. But i'm just doing it for a cleaning purpose. I'm not actually hoping to cut any material from a clearance perspective. Each time i've cleaned a set of cyls, i've followed that with bore gauge measurements and they check out OK, both in terms of cyl dimensions (ovality & taper) and clearance with the pistons going in them.
If I were to hone the cyls with that Goodson hone, I would make only a few passes just to clean them up. If I needed anything truly honed to size, i'd send them out to someone who really knows what they're doing with Nikasil like US Chrome, Millenium, etc. Farking up a set of cyls gets expensive when you have to strip & replate them all. I had one done by USC a few years back (cyls had previously been bored to 98mm & one had a sizeable chip coming off at the top) and it was $167 with my business/jobber pricing. $1000 is not something I want to spend after experimenting with the Goodson hone & oil.
Millenium replated mine. $1200. One cylinder had more porosity showing after replate so had to buy another cylinder $150. Then had to have that cylinder bored to correct size to match the bad one and then have the cylinder replated $200. Now $1550 in for a set of cylinders that probably would have been fine if I hadnt taken them to a shop that assured me they could deglaze them. It was not a Porsche shop btw.
Try not, Do or Do not
If the intent is to deglaze rather than recondition, red ScottBrite and hot water and soap is the technique we've used for years.
A few years ago we did some research on bottle brush hones specifically designed for Nikasil and the test results showed an RA factor far too high to ensure long ring life. I've been told that there are some new hones available but the specifications of the"new" hones seem remarkably similar to the old hones offered for years. The bottle brush hones we tested showed extremely high wear in race engines that were built every 50 hrs or so. As much as .040 gap increase between rebuilds.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Air Medal or two
Henry
Most the "new Guys " are not going to know What RA is . I have discovered us older guys have to revamp our nomenclatures PS You new guys welcome here, but dont reinvent the wheel, and Henry is in the center of the mark. Well worth paying atn to!
Ill ask for everyone, what is RA?
Air Medal or two
Google "rock well hardness"
Its a way of measuring what the material is worth that you are working with
Ah. For some reason I read his post as the test had been done to the cylinders, not the hone material. RA makes sense now.
From an old thread
do I need to hone this? Quote:
So the tests ng was done to the cylinders and the Ra is not related to rockwell hardness.
Schleprock
The Ra reading on the gauge John is holding in those pictures is giving a measure of surface roughness. Check out John's videos on youtube username "fiatnutz" to get some insight on what he does. The guy lives and breathes automotive service and development.
