Flywheel removal problem
i have an 81 sc motor that came into my possession largely disassembled. I am trying to sort out how to remove the flywheel. I am missing the starter ring, and I cannot tell if it is required for the use of porsche tool 238a. i don't want to buy the tool if it needs the ring to work. A mechanic friend of mine said that if I used an air powered impact driver I could just zip those bolts right out without any porsche tool, but I am nervous that I will turn the crank in the process and foul things up (the pistons have been removed) Has anyone worked these bolts out without the porsche tool? Any advice would be really appreciated.
Thanks!
Old 01-12-2014, 04:15 PM
non-whiner
mreid's Avatar
Get a heavy piece of strapping (Stanley makes one in the hardware section of HD or Lowes made for reinforcing a fence gate). Drill out one of the end holes so it slides over the upper right tranny stud. Bolt one of the other holes to the flywheel using one of the pressure plate bolts. Now you have the tool for less than $10.
"Too much is just enough."
Old 01-12-2014, 04:22 PM
Picture worth a 1000 words. Hope this helps.
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 01-12-2014, 04:32 PM
Smile You are both great Americans!
Thanks!
Old 01-12-2014, 04:43 PM
You can use a box end wrench the same way.
Old 01-12-2014, 07:25 PM
Air Medal or two
afterburn 549's Avatar
dont for get HEAT on the bolt !
ESP if they were loctite in
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 01-13-2014, 11:43 PM
