LinkBack | Thread Tools |
Rating: ![]() |
My 3.2L Deck Height, Piston to Head Clearance Measurements and Compression Ratio
Went ahead and did some final measurements to prepare for final installation of my pistons and cylinders.
I only took measurements from #1 & #4 pistons/cylinders for this step. Deck Height Measurements For both piston/cylinders #1 and #4 I used: - A single 0.25mm cylinder base gasket - Cylinder held down with 4 Stomski cylinder nuts, finger tight - Vernier caliper placed against the top of the cylinder wall, extension protruding/resting against the flat outer edge of the JE piston Piston #1 deck height measured 1.03mm Piston #4 deck height measured 1.09mm Satisfied with these #'s I figured I would move on and check the piston to head / combustion chamber clearance on #1. Piston to Head / Combustion Chamber Clearance I used the solder method described in Wayne's Engine Rebuild book to measure the clearance between the piston and the head's combustion chamber. I had some 3mm solid core solder handy so I used it. Wayne's book recommends acid core. Other than the possibility that the acid core crushes a bit easier - I can't see how the solid core solder result in a significantly different measurement as compared to the acid core solder (after all - this process is really just a sanity check as opposed to looking for a precise measurement/specification - or at least as it relates to a non-race engine). For piston #1, I came up with the following clearances (measurements of the crushed ends of the solder): - 2.04mm and 2.05mm (Two pieces of solder placed on the outer edge of the piston/against the cylinder wall and parallel to the piston pin). Thoughts on the Solder Crush Measurements While these measurements appear a bit large, I wasn't surprised considering my heads cc'd larger than expected: Measuring Head Volume / CC's / Compression Ratio Either way - it is what it is. Compression Ratio Calculation With the deck height measurement, I can now run my numbers for my compression ratio (I've been using this calculator 404page.html - 95mm bore (3.2L engine spec) - 74.4mm piston stroke (3.2L engine spec) - Leave calculator fields for head gasket bore & thickness blank (it is considered in the deck height measurement) - 92.4cc combustion chamber volume (measured in above link) - 35.1cc piston dome volume (from JE specs for 9.5:1 pistons). - 1.03mm piston deck clearance This produces a compression ratio of 9.16:1. While I would have liked to have been closer to 9.5:1 compression ratio - the larger volume of my head combustion chamber accounted for the CR drop. Good to go. I should have a solid, safe running engine that leaves plenty of room to rev and play with timing. Fun stuff, Gordo
Don "Gordo" Gordon '83 911SC Targa |
Project Addicted
Excellent work on all the posts. I will be using it for reference in our upcoming 3.4 build. Can't wait!
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
Thread Tools | |
Rate This Thread | |
