abit off center
cgarr's Avatar
Could just be getting some oil in thru the intake? check the vent/vac system and make sure you have the restrictor (aka dog dick) at the line to the oil tank and its the correct way.
______________________
Craig
G2Performance
Old 04-07-2014, 05:58 PM
nene's Avatar
All I can say is, "Many thanks to all who have taken their time and effort in providing quality feedback"! And truly, this is fantastic place with great people!
Serge
Old 04-08-2014, 08:55 AM
nene's Avatar
Something to add to this Dilemma - I have been hearing a sorta "Knocking" sound around the same area where the "leaky" valve resides (cylinder 5). It only exists at certain points in time and not an on going sound. Note: and it is not the valves for sure. I am beginning to think this maybe related? Would a broken valve spring be the culprit? And BTW, I am showing a slow loss of oil and burning through the exhaust.
I am planning to take the passenger side intake off to take a look at the leaky valve in question, and wanted to know if I can do anything that can point to maybe having a loose
valve or guide?
I am thinking of having a leak-down test done for once and for all.
Thanx,
Serge
Old 04-23-2014, 09:22 PM
nene's Avatar
I am reviving this thread....
Over this weekend, my car was driving like a MO-FO, for which it felt like it was going to dump me on the side of the road. The idle was lower than usual, the car was shaking like it was running on one or two pistons.
I decided to look into it and first thing I noticed was that my intake manifold bolts were all loose..? Anyhow, while I had the intake off, I decided to take a peek at cylinder 5 and check on the previous oil leak that was there, and low-and-behold, it was there! This time though, I decided to open up the valve and taking a peek in there, and what did I see...the exhaust valve covered with some black soot!
So experts, would it be wise to take the car over to my Wrench to have them assess the situation, or should I take a stab at performing something that might fix this? Opinions please??
FYI, after buttoning everything up, the car is now running like..a CAR!!!
Thanx,
Serge
Old 06-23-2014, 04:06 PM
Thanx,
Serge
My advice is to worry less and drive more. Stop taking off your intake manifold.
-Andy
Old 06-23-2014, 05:54 PM
nene's Avatar
Any other suggestions?
Serge
Old 06-27-2014, 12:04 PM
Straight shooter
Lapkritis's Avatar
Serge
My suggestion would include
-Andy
..and also add Techron to the fuel at each fill up. If it's hitting on all cylinders and healthy then give it an Italian tune-up. Enjoy. Repeat.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-27-2014, 12:32 PM
nickd's Avatar
Are you sure that it's oil? Having any cold or hot start issues? 181k miles and original injectors could be getting sticky. Suck it out with a syringe and see how easily the "oil" lights on fire. Injectors can be sent off and cleaned easily enough.
If it's oil, then definitely Italian tune-up followed by cold beverage. In that order only!
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 06-27-2014, 12:41 PM
nene's Avatar
nickd,
No hot or cold issues, although I do get "the oil smell" upon coming to a dead-stop, which I am associating this leak to, but I could be wrong. Spark-plugs are ok except this one, which has a little bit of oil around the thread.
Old 06-27-2014, 01:35 PM
