p to v clearance
Is it possible to have too much piston to valve clearance?I wasn't able to touch the piston with the valve screwed all the way in at the proper crank positions.Thanks,t.c.
Old 01-24-2014, 03:18 PM
What were you building?
Bruce
Old 01-24-2014, 04:41 PM
a 2.7 8.5 cr
Old 01-24-2014, 09:25 PM
I don't think it's possible to have too much clearance, but it is possible you did the check wrong.
-Andy
Old 01-24-2014, 10:08 PM
Air Medal or two
afterburn 549's Avatar
Contrary to what i used to know..The valves are closer to piston at mid stroke then any other point
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 01-26-2014, 10:27 AM
I don't know what this means, but the intake valve is closest when the pistons is just past TDC and the exhaust valve is closest just before TDC. I check at around 5 to 10 degrees either side.
-Andy
Old 01-26-2014, 07:03 PM
Air Medal or two
Yes, at the overlap
Old 01-26-2014, 08:04 PM
What's your deck height set at?
Old 01-26-2014, 08:17 PM
