tharbert's Avatar
Rod Small End Bushing Question
I had my rods worked over by a local machine shop. I've been measuring them and noted one specification was off by quite a bit. The bushing he used on the small end is narrower than that called for in Wayne's book. Mine appear to be about 24.98mm while Wayne's book says it should be 25.98-26.00. Is this significant for a non-race motor? Was this extra bushing material for heat transfer? As you can see in the pic, the bushing still extends proud of the rod casting by quite a bit, just not as much as it should.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 06-04-2014, 07:12 AM
Alan L's Avatar
As long as the internal diameter is a good fit (I think they are usually individually honed to the gudgeon/wrist pin) it should not be an issue. Maybe vary between manufacturers?)
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-04-2014, 04:54 PM
