20/21 cams on a 3.5
would appreciate your oipinion on:
3,5 engine twin plugged:
3,2 crank
JE pistons 100mm 11.5 CR
20/21 cams
bosch motrocinic
3,2 standard exhaust
Old 02-01-2014, 07:16 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Great choice for all around fun. They accelerate like a freight train.
I built almost the same engine 12 years ago.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-01-2014, 07:46 AM
20/21 cam
wow thanks for your expert information.
I hope to use 91 gas on it with a knock detector
Old 02-01-2014, 07:50 AM
DC 20 cam not DC 20/21 cam
Hi Henry,
My cam is a DC 20 and not DC 20/21
can I still use it in the above motor I described?
what valve overlap do you suggest?
will it run on 91 pump gas?
thanks,
George
Old 02-01-2014, 09:01 PM
camgrinder's Avatar
Originally Posted by greyes59 View Post
Hi Henry,
thanks,
George
The 20/21 is made by Web cams not me.
The DC20 is a little bigger compared to the web 20/21, the closest grind I have is the DC19. I would not recommend either with 11.5-1 compression and 91 octane.
Even if you went with twin plugs the tune up window would be narrow.
Something a little bigger like the Dc24 would work well (with twin plugs).
John Dougherty
Dougherty Racing Cams
Old 02-02-2014, 09:21 AM
I was thinking a little less compression as opposed to a little more cam. It's a street car after all with street exhaust after all.....
Henry Schmidt
Ph: 760-728-3062
Old 02-02-2014, 10:03 AM
camgrinder's Avatar
I agree. 10.5-1 is better.
John Dougherty
Old 02-02-2014, 10:59 AM
Dc 20
I thank the experts!
Old 02-02-2014, 01:46 PM
Project Addicted
I would like to ask an Octane question and not hijack the thread.
We are building a 3.4 based on a 3.2. We have JE 10.5:1 pistons, twin plug heads and 20/21 cams to install. This will be a street car DD and would like know what static compression ratio would have to be to use 89 Octane fuel is possible. With current heads chamber at 92.5cc and a deck height of 1mm this calculates to 10.1:1.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 02-04-2014, 10:37 AM
camgrinder's Avatar
You can make it work at 10.1-1 with twin plugs. Put the cams in at 1.8mm instead of the 2.2mm setting. About 114 or 114.5 degree intake centerline.
John Dougherty
Old 02-05-2014, 08:05 AM
Project Addicted
John, Thanks for the info!!
Jon
1966 912
1986 944
Old 02-05-2014, 11:50 AM
Project Addicted
John,
Would be considered advancing the cam slightly?
Jon
1966 912
1986 944
Old 02-11-2014, 05:18 PM
camgrinder's Avatar
John,
The 1.8mm setting is about 2 degrees retarded from the 2.2mm setting. Close the valve a little later on the compression stroke will help with your combo on 89 octane.
John Dougherty
Old 02-12-2014, 08:07 AM
Project Addicted
Ahhh ok. I understand that! I had a 50/50 chance of getting it right, whether advanced or retarded and of course I guessed wrong...just like when plugging something in, I always have to flip the plug.
911 Cam timing to those of us that has spent their time around american V8's or other less sophisticated engines is enough to give you a stroke! I appreciate your help very much.
Jon
1966 912
1986 944
Old 02-12-2014, 09:17 AM
camgrinder's Avatar
Your welcome Jon. I use the Porsche lift at overlap method when I build a Chevy engine too. With an adjustable timing set I find it easier to hit the lift number and then check the opening and closing. Having a "cam doctor" makes it easy to have the right numbers etc. My pick up has a "Chevy" 400 cu in engine in it.. just no GM parts are used. LOL 20130928_204359.mp4 - YouTube
John Dougherty
Old 02-12-2014, 11:49 AM
Project Addicted
John, That's a sweet pickup!! Quick too. Are you running an early 70's 400 small block??
Jon
1966 912
1986 944
Old 02-12-2014, 02:19 PM
camgrinder's Avatar
Thanks. Its an early sbc type engine using a Dart little M block. Makes about 650hp n/a and I have about 500hp of nitrous to add when the situation requires it
John Dougherty
Old 02-12-2014, 02:39 PM
