chain boxes
I am rebuilding the engine in my 993 and the chain boxes show some pitting where the seal to the cover sets. The covers also show similar marks, although more like chipping, where the seal sets into the groove. The rest of the boxes and covers look fine. I washed them initially in a parts washer which has only had econosolve in it. I believed these to be aluminum and econosolve is safe for use on aluminum per the manufacturer. The marks were visible before cleaning, so I do not believe these to be related to cleaning. I used a brass brush in the seal grooves while cleaning.
So, what to do. Do I add a sealant? Can I lightly sand the groove in the cover smooth or at least smoother? Do I do both?
I would love to just replace the boxes but they are not cheap. I have looked on ebay but have not been able to find a complete set.
Jim
Old 02-02-2014, 08:10 AM
Jim,
I do not know the answer, but pictures may spark some comments and suggestions. There are very knowledgable people that respond.
Bob
Old 02-03-2014, 07:07 PM
I'm on vacation, will return on Saturday night and post pictures on Sunday.
Old 02-04-2014, 03:58 AM
Straight shooter
Lapkritis's Avatar
Sounds like a job for JB Weld if you specifically do not want to replace or deal with welding to fill and then machine work.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 02-04-2014, 05:26 AM
Welding magnesium?
Old 02-04-2014, 05:36 AM
Straight shooter
Lapkritis's Avatar
Takes a specific rod and gas. Depending on the work it might be better to replace or use the aforementioned cold epoxy.
https://www.youtube.com/watch?v=tausy8soPzU
More than one way to skin this cat as usual.
Old 02-04-2014, 05:51 AM
