Crankshaft Cross Drill Oil Channel
Hi All
Will a center drilled main crankshaft still benefit from extra lubrication or at least have no detrimental effects if no groove is cut in either the crankshaft journal or bearing halves?
All responses appreciated
Old 02-19-2014, 04:54 PM
When I built my 3.2 I had my center main journal crossdrilled. I did not groove the crank journal or the bearing. I talked to two different expert builders and got two different opinions. One said it would help provide lubrication to the two adjacent rod bearings which are usually the last to receive oil pressure that normally comes from either end of the crankshaft. The other builder said crossdrilling is a waste of time unless you also groove the journal or bearing and open up the diameter of the oil supply passage in the engine case itself to the center main bearing. And you should also use a turbo oil pump if you want to really do it right. So the question is: do you really need it? What are you using the engine for? How fast are you going to spin it?
Old 02-20-2014, 12:48 AM
E-85 sippin drunk
turbobrat930's Avatar
Contact Mr. Mike Bruns at JB Racing in Florida....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 02-20-2014, 05:51 AM
How long has it been running like this?
Not really. If I had my choice I would have preferred it wasn't cross drilled but it was local and all other aspects of the crank were good including the price.
Non track use
Factory red line once in awhile.
Thanks for all your responses
Old 02-22-2014, 06:47 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Cross drilling is overkill for a non-tracked engine, especially if you're spinning it below 7000 rpm. There are tons of people who track/race their engines and the lack of cross-drilling isn't blowing these engines up regularly. It's only for the high revving engines for added insurance in getting the oil to the #2 and #5 rod bearings more effectively.
The theory/reasoning behind the cross-drill is because it is a known fact the crankshaft is fed oil from the ends. Main bearings #8 and #1 feed oil into the crankshaft and that's the source of oil for the rod journals. Since #2 and #5 rod journals are the centrally located rods, they get oil last. If oil demand/loss is high on the outer journals, then the inner journals like #2, #5 are going to suffer.
Also noteworthy is the #1 main journal is grooved, which helps the oil find its way into the drilling in the journal. #8 is not drilled I assume because the bearing insert is much wider and has a better ability to feed oil into the crank at that end? Not sure there.
The #4 bearing hole, and of equal importance is the hole in the case saddle leading all the way to the oil gallery inside the case, is enlarged to ensure the cross drill effect is taken advantage of. The larger hole is the path of lesser resistance and that means the oil path is going to be activated more easily than the surrounding paths that have smaller holes leading from the case main gallery to the main bearing saddles.
Here's a good thread with some pictures to describe what's going on with the oil path
Another crank cross drill question
Kevin L
'86 Carrera "Larry"
Last edited by KTL; 02-24-2014 at 09:37 AM.. Reason: Duh, forgot to paste the link.....
Old 02-24-2014, 09:34 AM
It sounds like you may have gotten this crankshaft already drilled and are wondering if there are detrimental effects to drilling? Based on your original post I would say there are no detrimental effects to cross drilling without grooving but there should be some benefit to lubrication of the two rods closest to the center main journal. I wouldn't worry about grooving it if you are just going to build a stock motor. I would say all upside in your case and no downside if you didn't pay extra for a mod you didn't really need. I have only a couple of thousand miles on my build but all seems fine with it. I guess I won't really know whether crossdrilling was good bad or indifferent unless I blow up the engine then tear it down and see.....
Old 02-24-2014, 09:11 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We cross drill every crank on every motor we build. Overkill ? maybe, but the process is cheap insurance. One of the cool things about building an engine that has 50 years of development is you get to incorporate everything you learn along the way.
We can groove your bearing with a one day turnaround.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-25-2014, 08:54 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Send the bearing to Henry for grooving, then forget it's all done. Why wouldn't you, regardless of it's intended use, since the hard part (crank) is already done! CHEAP insurance!
Gary R.
Old 02-25-2014, 11:00 AM
CaptainCalf's Avatar
+1
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 02-26-2014, 07:33 PM
