WUR serial number
Hi,
I have a question regarding the serial number of my Warm Up Regulator.
I can read the 0 438 140 serial number on the WUR, but there are no additional -1 or else next to it...
I need to replace the WUR and would like to do a core exchange, however it seems that I am missing an additional number to identify my WUR correctly...
(car is 911 SC from 1979, but I do not know if the WUR is original).
thks for your help!
Best,
Matt
Old 02-28-2014, 11:17 PM
pete3799's Avatar
US or euro model?
Pete
79 911SC RoW
Old 03-01-2014, 06:35 AM
E Sully's Avatar
Found this.
Ed
1973.5 T
Old 03-01-2014, 08:10 AM
Clean the top side.......
Originally Posted by matt2000 View Post
Hi,
thks for your help!
Best,
Matt
Matt,
Clean the top side of the WUR specially around the post. The number is 0-438-140-xxx. The first seven numbers were cast or molded on the body while the last 3 digits were stamped on it. Get a small wire brush or the like and gently clean the area. Either -045 or -069 on the engine if you have the correct WUR.
I could lend you a WUR if you need one and you don't have to buy it unless you want to keep it. Why do you think you need a replacement WUR? Have you tested it? Keep us posted.
Tony
Old 03-01-2014, 01:09 PM
