Curil T @ Cylinder base gaskets working time
Going to install cylinders this weekend. Was planning on having a local independent guy here install heads and towers, maybe next weekend. Can I put Curil T on the cylinder base shims when installing cylinders even though won't be torqued down with heads till next week? Should I just install the shims dry instead?
Thinking about letting local guy here finish up engine.
John
"Build a man a fire and he's warm for the rest of the day. Set a man on fire and he's warm for the rest of his life". -internet sage
Old 03-05-2014, 12:40 PM
Straight shooter
Lapkritis's Avatar
Okay to put on now as normal with Curil T. Hold the cylinders in place with a couple spacers under the head holts until your guy shows up. Stays gummy.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-05-2014, 01:14 PM
Thanks Lap,
Gonna load it up in truck next Sat.
John
Old 03-05-2014, 01:25 PM
Wer bremst verliert
JohnJL's Avatar
as far as ive experienced, curil t working time is at least 60 months. ive taken motors apart 5 years later and the curil was still tacky and flexible.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-05-2014, 08:05 PM
yup, and blue hylomar works just as well and never dries.
Old 03-06-2014, 02:13 PM
