How do you guys secure the small vacuum hoses
Hi guys
How do you guys secure the small vacuum hoses? With small tyewraps?
Old 03-09-2014, 08:08 AM
abit off center
cgarr's Avatar
Something like this:
______________________
Craig
G2Performance
Old 03-09-2014, 05:22 PM
DSPTurtle's Avatar
Tie wraps work too.
Old 03-09-2014, 06:27 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Heat shrink tubing.
Bob
Bob Hutson
Old 03-09-2014, 07:02 PM
Walt Fricke's Avatar
Oetiker clamps are pretty cool. Porsche used them on pressurized lines. I use a tile nipper to squeeze them - much less expensive (and I had one already) than the prescribed tool.
However, I think I generally don't use anything on most of my vacuum hoses. Like the two on the SC distributor - they don't need any clamping. After all, the have a vacuum inside which is trying to squeeze (a little bit at the end anyway) the tube to the tube over which it is slipped.
However, where a line may be subject to pulling forces, a clamp may be in order. Or on the brake booster lines.
Hadn't thought of heat shrink - interesting.
Old 03-09-2014, 09:00 PM
Banned
I've use tiny tie wraps on vacuum hoses on motorcycles and cars for over 20 years and have never had a problem doing so (like Turtle said, they work fine).
Old 03-09-2014, 09:12 PM
proffighter's Avatar
Oetiker SS with inner sleeve (avoids damage at clamping area)
Easy to fit, durable, short said best for an application like that (and lightweight )
BTW @ Walt:
I used a crusher where I rounded the cutting edges...
Roland
930 Turbo '81 Too many modifications to list
Old 03-14-2014, 04:26 AM
... And I prefer one like this rather than a sideways cutter, easier to find correct clamping force and no damage to the clamp due parallel clamping
Roland
Old 03-14-2014, 04:34 AM
aquazulu2's Avatar
Originally Posted by HawgRyder View Post
Heat shrink tubing.
Bob
Neat!.. Never thought of that either.
Old 03-14-2014, 09:23 AM
Roland - that looks like what I use.
Old 03-14-2014, 11:06 PM
