through case bolt questions
hi, i just assembled my frist 3.0 case last week for my 77 930. when a tighten the case bolts about 4 or 5 of them felt like thay stretched before they clicked on the wrench. should i have used new case bolts ? also dose oil flow threw all 11 bolts? looked at oil diagram and it look like just top 6 in a row carryed oil maybe???? thanks in advance for any help . john
Old 03-18-2014, 02:33 PM
Straight shooter
Lapkritis's Avatar
How many lbs did you give them on the wrench?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-18-2014, 03:20 PM
i sent the wrench between 25 and 26 ftlbs. with a deep socket.
Old 03-18-2014, 04:18 PM
