safe's Avatar
Tight to turn enging
Hi
I have a 2 liter mag cased engine that is new to me.
Even with the plugs out the engine is unbelivebly tight to turn over (by hand) almost like frozen solid.
If I put a wrench on the pully I need like a 16" extension to break it free, then that movement is easy. If I continue to turn the engine over a full 360 degrees it loosens up and you can turn it without much resistance.
2 days later (or maybe less) and its frozen again.
The only thing I'm sure of is that the cam chafts is't binding, I could turn them when I inspected the chain tensioners.
Ideas?
Magnus
Old 01-25-2011, 08:58 AM
Consider oiling the cylinders while turning. I had a 2.2 T that had dry walls and wouldnt turn.
Bruce
Old 01-25-2011, 09:06 AM
safe's Avatar
I did spray some penetrating lubricator down the sparkplugs, but maybe I should use proper oil instead.
Forgot to say, I drove this engine home, 160 miles, in oktober. It has been untouched until I pulled it 2 weaks ago. The magnetic oilplugs did look a bit like a christmas tree....
Magnus
Old 01-25-2011, 09:23 AM
your mainline bore may be out of wack. 2.7s do that when you use new main bearings and don't align bore the mains. it's a mag case and mag is perpetually rotting and shape shifting.
206 637 4071
Old 01-25-2011, 09:29 AM
safe's Avatar
The answer I was sort of waiting for.... and fearing...
This engine has a previous rebuild on it some years ago, but it's only a little 2.0 so I hoped that it might be something else....
I think I will have to tear it down and have a look. I was planing on selling it, but that doesn't feel right like this. Possibly its better to part it out.
Magnus
Old 01-25-2011, 09:43 AM
I think that if the rotation frees up as you turn the engine over, it may not be due to the crankshaft bore mis-alignment. I have a 2.7 awaiting assembly (with a new line bore). Before teardown it wasn't stiff to the point of using a 16" breaker bar, but stiff enough where I had to bump it with the starter in order to do a valve adjustment (a wrench on the alternator/fan wouldn't do it via the fan belt). If I could reach the lower pulley bolt, it was consistently stiff and never loosened up.
I would try oiling the cylinders and/or try other options before assuming the worst.
Dave
'75 911s Coupe
Old 01-25-2011, 12:13 PM
Max Sluiter
Flieger's Avatar
The cases only relax and twist when the through-bolt tension is released.
Old 01-25-2011, 06:27 PM
safe's Avatar
Are you saying that if the case has warped it should always be tight and not release the crank after turning it?
What was strange was that when I turned the crank 90 degrees I had 90 degrees of free movement (relativly free) but it still reqiuered a lot of force to turn past the 90 degrees.
Magnus
Old 01-26-2011, 12:09 AM
NOS driver
If it is the 2 liter, it shouldn't be a MAG case, no?
Old 01-26-2011, 12:46 AM
safe's Avatar
The -69 (mine) are mag cased.
I think that even some -68s have mag case.
Magnus
Old 01-26-2011, 12:50 AM
NOS driver
thanks, didn't know that! I thought mag cases were used only from the 2.2 liters on.
Old 01-26-2011, 02:11 AM
Max Sluiter
Flieger's Avatar
No, I meant that while the engine is assembled, the through-bolts keep everything aligned as it was when first built so it will turn smoothly. When you dis-assemble the engine, the magnesium is able to "relax" to a warped shape. If you then re-assemble without line-boring, it will bind.
Old 01-26-2011, 10:51 AM
safe's Avatar
3 years later!
Today I split the case, and it is warped!
There are tell tale signs on the bearings and when I put a ruler over the bearing webs I can see that see that the middle bearings are a few tens lower.
Are there any tolerances for them?
Interestingly the crank was ground and the bearings were +0.50.
Magnus
Old 03-20-2014, 02:30 PM
faverymi's Avatar
When I had my mag case done the builder had a jig where he placed the half cases.
My mag case bit me in the butt.
If I was you I would send it to a pro.
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 03-21-2014, 04:09 AM
safe's Avatar
Well, I have no real use for the engine.
It either a fun exercise or a shelf warmer in my storage.
Magnus
Old 03-21-2014, 04:38 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
you will need a new, standard crank as oversized bearings are nearly unobtainable and when found are ridiculously expensive.
A fun project but hold on to your wallet ;-)
Chris
73 911 E
Old 03-21-2014, 07:24 AM
