abides.
Source for crank position sensor pin on flywheel?
I accidentally broke off the pin on the side of the flywheel which (I assume) triggers the 3.2's reference senders.
Anyone know where I can get a replacement pin? I see a threaded pin in PET (93010222100) but it's $74 from Pelican. Surely that can't be it... I hope.
Graham 1984 Carrera Targa |
Flywheel Threaded pin.
If you do decide to get a bolt from the hardware store, make sure that it can attract a magnet. (Ferrous metal) Ooops! I did not notice your 5400 posts general, please excuse the private... Last edited by aquazulu2; 03-25-2014 at 01:17 AM.. |
abides.
Thanks, aquazulu.
Unfortunately I think the sheared off head is long gone. I am going to attempt to replace it with the help of this thread: 3.2 motronic reference pin dimensions
Schleprock
$74.................... absolutely ridiculous pricing.
Should be able to get a black oxide carbon steel metric set screw at your local hardware store. If not, Belmetric can set you up https://www.belmetric.com/metric-set-screws-4mm-c-6_342_381.html
Kevin L '86 Carrera "Larry" |
abides.
Yes, that's why I was skeptical at first.
Shouldn't be too hard to find a suitable replacement. I think I have some of the correct size screws at home, but they are stainless unfortunately.
