Licensed User
twin ignition head temps?
Do any of the builders here have thoughts on whether or not using a twinplug setup on something like a 9.5:1 2.5L street engine would help reduce cylinder head temps or make the engine last any longer than normal? I understand it would be unnecessary, but would there be any benefit? Would it make oil temps more manageable or make the car run better on regular pump gas?
TIA Last edited by Shuie; 03-25-2014 at 01:26 PM.. |
Hi Shuie,
The timing reduction would lower cylinder head temps by lowering cylinder pressure BTDC. The lower cylinder pressure would also guard against detonation.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Max Sluiter
It will also give you a wee bit more power because you can run less advance.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
I would love to twin plug the2.5l in my 914/6 ... but is the expense worth the gain? Maybe 5% more hp? What is the overall cost? $3k ish?
Max Sluiter
I doubt it would be 5%. Maybe 1%. The real reason to do it is to allow for higher compression ratios (which on an old 911 requires a high-domed piston), which will make more power.
The gains transcend just BHP,.......you get improved throttle response, improved drivability, and lower cylinder head temps (which on a hot day, help VE's).
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
