2,0 -> 2,7 in 901/03
Hi there,
It is quite common to bore the Cylinder spigots from 92 to 97mm to insert 90mm barrels into a 7R mag engine case.
Actually i have got here a 901/03 (some 1 or 2R) and the idea came up to upgrade this one to 2.7L.
To me the contact surface where the cylinder would sit on would appear a bit tiny plus the pressure on the copper ring would probably be exceeding.
Question: Did anyone do such conversion on the earlier mag cases and if, what are longterm experiences?
Cylinder/Case oil leaks?
Cylinders "sinking"?
Thanks,
Robert
Old 03-27-2014, 11:22 AM
Hi Robert,
The early generations of magnesium cases were much more flexible compared to the later versions and as such, were prone to cracking.
Given the necessity of the extensive (major $$$$) machine work that ALL Mg cases need to work, those early ones are not a good choice when building a 2.7 due to their fragility.
I suppose if one used "T" cams to keep max revs below 6500, it may last acceptably long, however I could not offer such options to my clients, simply to protect their financial interests.
JMHO, but the 4R/5R & 7R cases are far better choices for a 2.7.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-27-2014, 01:38 PM
Thanks Steve,
i know about the overall fragility of the early cases. So not a good choice, i know. Especially the spigot area and its potential issues actually are my concern. Can you report issues with it when boring to 97mm as longterm experience?
Since i am my own machine shop i am not concerned about the labour.
I just never did such conversion on the early cases but on the later ones for the same reasons you state so i have a lack of experience here.
Old 03-27-2014, 02:13 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
When we enlarged some VW cases for bigger cylinders...we bored them with a step in the cylinder hole and inserted a steel ring (with as large a diameter as we could get in) and let the barrel sit on this.
It distributed the load over a larger area...and made the whole deal worth while.
Other than that...I would go with Steve...and get a later case...or grab an older Aluminum case (stronger) to use.
Bob
Bob Hutson
Old 03-27-2014, 05:58 PM
Thanks Bob, you made it that way for the same feeling and reason i never did the conversion i talked of.
Regardless of that: Anyone here who did it and has proven it can work?
Old 03-27-2014, 07:22 PM
Originally Posted by crummasel View Post
Thanks Steve,
Cracking is the problem here. Spigot cracks: main web cracks behind #3 to the flywheel seal area are the two biggest problems. This is why I strongly recommend retaining the 92mm spigot size since the very LAST thing one wants to do is remove any material from these flexible cases. I've seen a lot of this when these engines are operated over 6500RPM.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-27-2014, 09:05 PM
Thanks Steve, good explanation, the case remains as is.
Old 03-28-2014, 07:39 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Back in the day when there were limited suppliers of P&Cs we would convert 2.0-2.2 to 2.5 by installing the 90mm cylinders.
The concerns for cylinder support lead us to a compromise.
Instead of boring the case to 97 mm, we would bore it to 94mm and trim the cylinders to fit. This compromise added to our peace of mind and produced a noticeably more reliable engine.
With the advent of reasonable after market cylinders, our preference for these early cases is to leave the case spigots stock and run a 70.4 (2.4-2.7) crank with 86mm cylinders.
This produces what we call the 2450. With 9.5:1 compression, 36 mm ports and Mod "S" cams these little Weber carbed engines make 180 RWHP @ 6400 rpm. Well within the reasonable performance limits of the case.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-28-2014, 08:33 AM
Good point Henry, but that gave you a cylinder skirt of not more than 2mm. Has that been reliable with Nikasil Cylinders?
Old 03-28-2014, 10:45 AM
Although not a perfect solution, this modification was reliable.
Keep in mind that the early 911 engines had a very nice rod length to stroke ratio (1.97:1) so there was very little side loading on these cylinders.
Henry Schmidt
Ph: 760-728-3062
Old 03-28-2014, 11:23 AM
Hmm..
i am still a bit ambivalent as i actually ran out of cases.
I still have got a 4R, which already is (slightly) reinforced in the area Steve has mentioned.
But even if, it still apears to me difficult to let the barrels sit on a "flange" of remaining 3mm with spigots bored to 97mm (not really much better when boring to - say - 95mm).
Opinions?
Old 03-28-2014, 06:59 PM
