JE ring end gaps too large?
new JE 98mm pistons with their rings ready to go in my 1983 SC motor. Car will be used for the street and DE, not racing.
Their guidelines show .0045 x bore = .0174" minimum end gap for the top ring, but I suspected this was for big cast iron block engines so I called them. They said I could use .015" for my air cooled.
Porsche specs show .008" minimum gap. I am still using the same basic jugs (bored 95 to 98mm), but shouldn't the gaps depend on the ring and cylinder material and configuration, which really can't be much different? Why would the aftermarket ring gaps be expected to close up so much more than what Porsche thinks?
I don't want to seize my engine, but I do want as much compression as I can get safely. Any thoughts or experience on these ring gaps? Thanks.
Old 04-02-2014, 12:50 PM
sjf911's Avatar
That is the same recommendation that I got for mine (0.017" on a 98mm jug).
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 04-02-2014, 02:37 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you are looking for the best compression/leakdown numbers you can get with the pistons you have....why not look into Total-Seal rings?
I believe the standard placement is in the second compression ring position.
Bob
Bob Hutson
Old 04-02-2014, 05:11 PM
Better to go bigger . . . won't hurt.
I run 0.012 - 0.016 in my 2.7 (90mm) race motor. Never any problem.
Dave
Old 04-02-2014, 05:19 PM
end gap
You need to follow the formula from JE based on your engine build, we have tested and found no power difference, the problem will be if at temp the rings butt when the gaps are too tight.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 04-02-2014, 05:54 PM
Many thanks for the replies. I know a larger gap is safer but I'm like the kid who always asks why so I can understand.
With a minimum gap twice what the factory says, while using the same basic cylinders, it threw a red flag. I try to pay attention to those flags rather than follow blindly. The guy I talked to at JE did not instill confidence.
Always thought I would try the Total Seal sometime, but I want to limit my variables and use the rings JE provided. If Mike and Dave say that a larger gap doesn't make any difference in power, then I feel better. I will go for .015" which is at the high end of Porsche's range and move on.
Rick
Old 04-03-2014, 06:21 AM
