Diving in 911
Inserts on a 2.7, 7R Mag case?
So this is from my case with one of the studs removed. Trying to determine if it has had inserts installed. The head studs are steel and it is a 7R Mag case. The book is not entirely clear (to me) on if the studs can be reused. What I have drawn is that the steel studs in a 7R case should be left alone if they have not pulled. I also have one stud that is in 5.21mm farther than the rest, Any thoughts. It has "Nickies" if that should factor.
Thanks again to everyone. I will be posting picks of my progress for others new to this rebuild thing, could be helpful...
Old 04-26-2014, 12:14 PM
The inserts into the case would be magnetic and you would want to install dilivar, or the like to run with the aluminum cylinders.
Dont throw the studs away, I can use them.
Bruce
Old 04-26-2014, 12:23 PM
Diving in 911
Dilivar replacements
Bruce
So they are not magnetic would the same be try for case savers? Since you are willing to take used steel studs, could the same be true of me fining used Dilivar studs? Does the 7R case alleviate the need for case savers? Send me a PM with the subject and Ill let you know when these are out.
Chris
Old 04-26-2014, 01:19 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Used studs to me are like buying a cut rate cheap parachute!
You can...but you should not.
Older studs have been flexed a bunch...how many times?
I like the security of KNOWING what is inside...saves a lot of $$ in the long run.
Bob
Bob Hutson
Old 04-26-2014, 01:47 PM
Air Medal or two
afterburn 549's Avatar
Dont re use studs !
Its not worth not unless you like to do it over.
Steel are not that expensive and well worth piece of mind
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 04-26-2014, 02:53 PM
studs
Use your head and use the SEARCH feature. There are more posts on that subject than almost any other.
Old 04-27-2014, 01:29 PM
Air Medal or two
There is SO much information on studs they guy could read for ever.
Last i knew steel was the way to go.
ARP is a over kill for most situations .
Old 04-27-2014, 01:41 PM
Vintage Owner
Jack Stands's Avatar
After all these years, case savers would be a good idea, and Dilivar has proven to be more of a problem than a blessing.
Original steel, ARP, or Supertec studs are all good ideas, just how much do you want to pay.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 04-27-2014, 08:42 PM
you need to speak with john walker, Walkers Workshop..
Old 05-11-2014, 08:01 PM
