non-whiner
mreid's Avatar
Engine troubleshooting anyone?
The 3.6 in my 74 (bought used and it's from a 92 964 with adjustable valves) has had a bit of popping through the exhaust, particularly during deceleration. I also noticed a slight amount of valve noise. Yesterday, the valve noise got louder and the popping more significant. I isolated the noise to cylinder 3 and the popping to the left exhaust pipe. I'm running PMOs, so I tested vacuum with my unisyn and all cylinders were pulling an equal amount, except #3 which had half the flow. I'm hoping this is just a valve adjustment issue (too tight or too loose). I'm pulling the valve covers today, but any other thoughts?
"Too much is just enough."
Old 04-27-2014, 06:15 AM
73 Sporto 911T-V RoW
DanPez's Avatar
The popping from the exhaust, on deceleration, is most probably a vacuum leak.
You confirmed when mentioning that your getting half the flow on #3 jug.
You can check the compression on that cylinder and compare it with the others, just to make sure the valves are seating well.
Exhaust popping is unburnt fuel escaping through the pipes.
Daniel
Old 04-27-2014, 06:28 AM
Straight shooter
Lapkritis's Avatar
Did you attempt adjustment of the carb for #3? Perhaps a bad or missing bypass screw seal.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-27-2014, 10:33 AM
porschetub's Avatar
Go for the air leak test to start with as that could be your problem ,are the carbs set up right (excluding your problem)?,hope its not a bad valve.
Could be a dry or rolled "o"ring afterall.
If so do a hot compression test targeting that cylinder (mainly),hope you don't come to this,cheers.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 04-27-2014, 10:15 PM
If the problem is progressive, which it sound like it is, I doubt it is a missing part causing it. I'd be inclined to check the valve adjustment on the #3. Sounds to me like it loosened up...
Tell it like it is or don't tell it at all.
Old 04-28-2014, 05:46 AM
