Main Bearings +0.25mm
Hi there,
i am urgently after one set bearings 1-7 for a linebored case +0,25OD.
Numbers are 901.131.60 for #1 and 901.132.60 for #2-7.
Alternatively 2pcs of 901.132.60 would serve me well as 2 are missing.
So either a really good set 1-7 or just 2halfshells to complete my set to let them get recoated.
For info, i am looking for the early ones, its a '74 case
Probably not right here, but these small things may perish in the sale section...
Thanks and greets,
Robert
Old 05-01-2014, 05:52 PM
Only available at the dealer
regards
Old 05-02-2014, 06:53 AM
.25 bearings
Robert, I may know where there is a new set, I will check and let you know possibly tomorrow
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 05-02-2014, 04:26 PM
Hi Mike,
meanwhile i may have a chance at Porsche directly, they are still due to confirm.
I will feed back.
Thanks a lot.
Greets,
Robert
Old 05-02-2014, 05:31 PM
bearings
Robert, JB Racing has a set on the shelf from many years ago, we ended up going with an early alum case for that build. While waiting on Jim to check to see if he had them and a price I checked and the factory has several sets in Germany. Jim wants 550.00 for the new set. His phone # 352 343 8900 JBRacing.com
Mike Bruns
Old 05-06-2014, 05:15 PM
Just to update: I got the +0,25mm bearing shells from Porsche @ ~28Eu each #2-7 shell and ~45Eu each #1 shell.
Old 06-01-2014, 03:23 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec has a huge selection of NOS 911 bearings including both undersized and oversized sets and some individuals. We even have some bearings in .50mm.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-03-2014, 03:22 AM
