Is clutch smell normal after rebuilt
Did my first drive after rebuilt.
I have a faint clutch smell after the drive. Clutch was like new purchased it on the board Flywheel and pressure plate were machined. Thanks Erick |
Straight shooter
Clutch smell, not normal in my experience unless you're slipping it a lot or driving aggressively. Perhaps something else is burning in and releasing fumes such as exhaust paint or other coatings. Check your clutch arm (if so equipped) to ensure it is releasing tension fully.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Thread Tools | |
Rate This Thread | |
