Smoke on decelleration
I recently just purchased a 1980 911SC with a ROW 3.0L engine. The engine runs very well and strong but has a smoking issue on deceleration. The owner I purchased the car from was very honest and told me about the issue. He said he was driving the car one day and it starting smoking so he did a compression test with results of 160+ on all cylinders. His mechanic said it may need new valve stem seals. The car has been parked for around 2 years since the problem occurred because the owner was unsure of the problem and did not want to harm the motor. He must have started it on occasion because it does start up rather well. Any ideas if this could only be a head issue? If so I have seen a lot of good things written on Anchor Atlantic Enterprises on rebuilding heads. Thank you in advance.
Usually, if you need valve stem seals, you need valve job to go with them.
Bruce |
is the oil consumption within factory specs,are the spark plugs showing oil fouling?
what oil are you running?
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
I have not checked the spark plugs since purchasing the car. The owner did say he was running Royal Purple oil made for aircooled motors.
As Bruce pointed out, if seals are going, there's probably other head components that are out of tolerance. It you have to pull the heads to replace the seals, you might as well have them rebuilt. Along with seals wearing out, the guides get out of tolerance and heat transfer from stem to guide suffers and can eventually lead to burnt valves. BTW, I used Anchor Atlantic for my heads. They look great!
I too had smoke on deceleration. I was running 10-30 but I raised the viscosity to 20-50 (dino Castrol) based on something I'd read here and they were right. With the higher viscosity, it didn't smoke as badly. You may be able to get a few more miles before tear-down.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
All my cars get oil changes after I buy them to brands that I know and have trusted in the past. To me its all about what oil the car was using in the era it was made,had a friend put Mobil one in a freshly run-in 356b motor......it leaked everywhere and smoked,he went back to an old-school oil and all was good.......just saying. Get those plugs out check them for deposits,you could also check the guides when setting the valve clearances. I remember Bruce Anderson saying that not all these motors had valve guide issues and some went to huge mileages untouched.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. Last edited by porschetub; 06-11-2014 at 02:53 PM.. Reason: spelling |
I developed a smoking and oil consumption issue out of the blue. Did the usual leak down tests, spark plug check, etc and everything was good. Pulled the heat exchangers and found #2 exhaust port was oily. Pulled valve cover and looked real close at the valve seal and it had come off the guide.
I bought the spring compressor tool and replaced the seal with a new teflon seal and all is good. While I had the exhaust off, I rotated the engine to get each valve off it's seat and pushed on the valve with a large screwdriver to check for play. All guides were tight, no play detected at all. The valve that I removed the spring on I was able to put apposing forces on both ends. No play at all. Tight as a drum. Bottom line, valves seals can be a problem even if guides are tight.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
When I purchased the car I was thinking the heads would most likely benefit from a rebuild. from what it sounds like and the symptoms I have, would it be safe to say the heads most likely need rebuilt? Thank you for the responses and help so far.
