LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Well, wasn't the key. I put the other side on and it is identical.
Can't go any further without some advice on this.
Someone please chime in!
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 03-02-2015, 04:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
michael lang's Avatar
Originally Posted by Amstaff View Post
I put this in a separate post but should the shaft protrude further than this?
Are you referring to the little pin not going in all the way? Or is there a problem with the cam not going all the way into the carrier?
Mike
'89 CARRERA
#402
Old 03-02-2015, 06:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
Not the pin.
The fact that the cam shaft does not go all the way to the end of the sprocket.
Seems like it should
Tom Feeney
1970 911 T
1973 911 T
Old 03-02-2015, 06:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
Found this picture that seems to show the same thing.
Maybe it is correct.
Tom Feeney
1970 911 T
1973 911 T
Old 03-02-2015, 06:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
Chain alignment
So checked chain alignment and this is what I got on the right side
This is the left side
Both are within specs
Tom Feeney
1970 911 T
1973 911 T
Old 03-08-2015, 04:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #185 (permalink)
Cam and chain assembly
I put the cams in with the key way pointing up and the dot as close to straights as I could get it.
Tom Feeney
1970 911 T
1973 911 T
Old 03-08-2015, 04:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #186 (permalink)
Chain and tensioners
I took the tensioners and bled them. Simple yo do, break the bleeder nut loose, put it in a vise and SLOWLYcompress them. I did a little at a time backing them off every turn of the vise. When I could compress them with my fingers they were good to go. Tightened the bleeder and installed them. Large channel locks on the tensioner and a large screwdriver to pry the chain tensioner up and tapped them on with a soft dead low hammer.
Got both on and the chain is nice and tight. Once the cams are timed I will put oil in the top and pump them back up.
Tom Feeney
1970 911 T
1973 911 T
Old 03-08-2015, 04:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #187 (permalink)
#1 and #4 rockers
Put both necessary rockers on and torqued them to specs. A long extension with a 5mm Allen driver does the trick.
Tom Feeney
1970 911 T
1973 911 T
Old 03-08-2015, 04:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #188 (permalink)
When you install the rockers make sure that the rocker shaft in even with the narrow side of the rocker shaft hole. That way the shaft will be centered in the rocker arm and it won't leak.
Now for the part that I am dreading...... TIMING THE CAMS!!
If you have a good link or suggestions on setting 964 cams in a 3.0 please post it for me.
Tom Feeney
1970 911 T
1973 911 T
Old 03-08-2015, 04:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #189 (permalink)
Besides it taking several tries to get it right timing the cams are not as hard as I thought. I made a post looking to borrow the tool to hold the cam while it is tightened. As soon as I locate one I will post a how to.
If you have one that you wouldn't mind renting or loaning I would happily pay shipping.
Tom Feeney
1970 911 T
1973 911 T
Old 03-09-2015, 06:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #190 (permalink)
After reviewing my old pictures I realized that the left cam gear was on backwards. Pulled it and flipped it over. I think the chain alignment will be the same but I am going to check it again tomorrow evening.
Tom Feeney
1970 911 T
1973 911 T
Old 03-10-2015, 04:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #191 (permalink)
Right gear goes on with the cupped end I and the left one with the cupped end out.
Tom Feeney
1970 911 T
1973 911 T
Old 03-10-2015, 04:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #192 (permalink)
Chain alignment
Checked my chain alignment and all is well.
Here is how you check it. First, with your straight edge measure the distance that the gear on the intermediate is from the face of the case. For my 3.0 you go through the hole at the bottom. Zero out the gauge when it touches the intermediate shaft gear. Check it a few times to make sure it is at zero
check the right hand gear holding the straight edge on at the same location that you checked the intermediate shaft gear. Check Wayne's book for what variance is allowed.
Tom Feeney
1970 911 T
1973 911 T
Old 03-12-2015, 12:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #193 (permalink)
Chain alignment
Then check the left gear. Again, check Wayne's book for allowable variance. I just hate to post specs when there are different specs for different engines.
Tom Feeney
1970 911 T
1973 911 T
Old 03-12-2015, 12:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #194 (permalink)
Cam timing
Now on to cam timing!
No worries... I have this!
Look for updates Sunday
Tom Feeney
1970 911 T
1973 911 T
Old 03-12-2015, 12:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #195 (permalink)
Timing
Start by installing the rocker arm for #1 and #4 making positive that they are both set properly with a feeler gauge.
Make sure the distributor is pointed at the mark that designates #1
Now back the engine up until the indicator quits moving which is just under 1/4 turn.
With the Z block in place and the indicator sitting on the top outer edge of the spring set the dial indicator to zero.
Tom Feeney
1970 911 T
1973 911 T
Old 03-12-2015, 04:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #196 (permalink)
Cam timing
On my 3.0 with 964 cams I am going with 1.26 mm so rotate the engine until the indicator reaches 1.26 mm. If the Z mark isn't exactly lined up with the engine parting line pull the pin and rotate the engine followed by reinstalling the pin.
Oh, and stuff a rag in the bottom of the chain housing, I had a close call with the cam sprocket pin.
Once you have it set right torque the bolt down using the correct tool.
Then do the other side.
Tom Feeney
1970 911 T
1973 911 T
Old 03-12-2015, 04:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #197 (permalink)
Cam timing
Tom Feeney
1970 911 T
1973 911 T
Old 03-12-2015, 04:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #198 (permalink)
Cam timing
Then set the distributor to #4 and repeat
Tom Feeney
1970 911 T
1973 911 T
Old 03-12-2015, 04:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #199 (permalink)
Once torqued down check the setting one more time to make sure that it didn't move.
Then.... Cam shaft timing is done!
Tom Feeney
1970 911 T
1973 911 T
Old 03-12-2015, 04:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #200 (permalink)
