-   -   Rookie 3.0 rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/817029-rookie-3-0-rebuild.html)
Amstaff 04-10-2015 05:39 PM
Motor install
http://forums.pelicanparts.com/uploa...1428712741.jpg
Just need to tidy up loose ends
http://forums.pelicanparts.com/uploa...1428712795.jpg
Amstaff 04-10-2015 05:41 PM
Just need to wire the distributor, install fuel lines and plug in the loose wires. Headers won't be here until next week so I am trying to decide if I should put the old ones on and run them for the break in period.
michael lang 04-11-2015 12:24 AM
just out of curiosity, why did you not finish the reassembly before putting it back in your car? I would think it would be easier for access to everything vs. having reach in and feel your through everything and crawling around on your garage floor.
Amstaff 04-11-2015 05:27 AM
What do you mean by finishing the assembly? What else should have I put on it?
The reason the alternator wasn't on is it needs to be wired, carbs because I have always had clearance issues with the carbs on because I usually can't get the car high enough and the coil can't go on until the alternator is on.
Otherwise the motor was pretty much together. If you think I should have at least had the carbs on you are 100% correct, if I thought the car was high enough it certainly would have made it easier. I just remember the last time that I didn't have the car high enough and had to pull them off to get the motor under the car.
Amstaff 04-11-2015 05:28 AM
Funny how it took 3 hours to remove the engine and 7 hours to put it back in.
mreid 04-11-2015 05:45 AM
Don't you love how that works! Seems the time space continuum becomes warped on reentry.
Great job all around!
Amstaff 04-11-2015 06:21 AM
Gravity is your friend when you pull the engine and your enemy when you install it!
michael lang 04-11-2015 06:41 AM
You just answered my question. I figured it might be as much as a clearance issue but wasn't 100% certain. You could have always gone with something like this
http://images.tapatalk-cdn.com/15/04...b1889c9faa.jpg
Those blocks combined with my jack stands gave me this this height at the rear bumper
http://images.tapatalk-cdn.com/15/04...cabd5664c9.jpg
I haven't gotten to re installation yet, I can't wait for that adventure
toddu 04-11-2015 06:45 AM
Midrise lift and a hydraulic table = 30 minute job. :-)
Todd
Amstaff 04-17-2015 04:18 PM
Headers are here!
Now if I can just find the Delo SAE 30 oil I will be ready to start it up!
Amstaff 04-18-2015 05:11 PM
Filled it with oil tonight. I was really expecting a flood of oil to come pouring out of the bottom but not a drop!
Tomorrow night exhaust and start up.
mreid 04-18-2015 06:45 PM
The three milestones of engine rebuilding:
1. Installation - exciting
2. First Start - nerve racking
3. First Drive - exhilarating
Amstaff 04-19-2015 04:47 AM
I am super nervous about the start up.
billybek 04-19-2015 05:54 AM
The squeeze at the back door is super tight when firing a new overhaul for the first time...
Good luck and post a video (of the engine, not the back door)!
mreid 04-19-2015 07:24 AM
Completely understandable! Particularly considering you have to run it at a higher rpm for 20 minutes to break in the cam/rockers.
The good news is that you will have super hearing the first few times you drive it!
Amstaff 04-19-2015 02:38 PM
Fire it up!
Well, fired it up tonight.
Cranked right up without hesitation and ran smoothly for its 20 minute break in period.
Not a single drop of oil and no funny noises!
Drained the oil and hardly a spec of anything in the oil!
https://youtu.be/rOlBurkiRMg
Amstaff 04-19-2015 02:42 PM
Now the big question.
I ran Delo SAE 30 for the break in period.
Do I change it o 20/50 now?
911 tweaks 04-19-2015 03:58 PM
YES...especially simce u have run the break in which I would of used the Joe Gibbs Break in Oil but too late for that now...so going fwd use joe gibbs driven driven 15/50 = their DT50 as it has the hi zinc level...I use ONLY JB oils for ALL of my clients and my cars...period... not a spokesperson but NO other oil has this correct additive pkg on the market...recommended by LN Engr & jake rabey & others...hope your rebuild is what u hoped for...bob )))
Amstaff 04-19-2015 04:16 PM
Is that synthetic oil?
