Bad spot in case
I have seen this defect several times in this forum. My understanding is that it should not leak but to be positive clean it thoroughly with a small wire brush then clean it with brake cleaner, let it dry and then apply a smooth coating of JB Weld. That seems to be the fix that everyone recommends so I don't see there being an issue with it coming off.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 09-05-2014, 04:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Cleaning head stud threads
Well, today I cleaned the head stud threads. I took an old head stud, cut some slots in it to catch the nasty stuff in the threads.
Then I squared off the other end to fit it into the handle for my tap.
It worked perfect!
Tom Feeney
1970 911 T
1973 911 T
Old 09-13-2014, 12:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
GT2BH's Avatar
Nice method, I'm going to borrow it
Did a lot of bad stuff come out?
'09 997 GT2
'86 911 3.2
'83 911 SC (work-in-progress)
Old 09-14-2014, 03:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Head stud threads
Sure did, lots of junk came out of the hole. As you run the "tap" down the hole you break up all the old Locktite. Some metal came out but it was mostly Locktite.
Tom Feeney
1970 911 T
1973 911 T
Old 09-14-2014, 04:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Great thread. I'd like to do one someday.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 09-20-2014, 04:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Still at it
I know I am really slow but one thing I have learned is that building the engine takes time and you really need to be patient. Everything is ready to go to get the short block together. I just need to have the crank polished and I am ready to put the case back together.
I recently got a pair of 964 cams, plastigage and more sealant.
Hope to get an update soon with the short block going together.
Tom Feeney
1970 911 T
1973 911 T
Old 10-17-2014, 03:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
More goodies are here. New chain ramps and although I have already installed the old rings I have decided to attempt to hone my cylinders and install new rings. My crank goes to JB Racing Tuesday for polishing so I should be assembling the short block next weekend.
Tom Feeney
1970 911 T
1973 911 T
Old 10-25-2014, 04:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Parts
Tom Feeney
1970 911 T
1973 911 T
Old 10-25-2014, 05:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Oil pump and chain rails
Installed the oil pump today. Also installed the two chain rails on the right hand side of the block. Long side goes toward the gears and the lonely brown ramp goes on the bottom right hand side nearest to the crankshaft. I opted to mark my bolts with a dab of red paint so that I know which bolts are torqued and which are not.
Hope installing the pump doesn't interfere with plastigaging the crank.
Tom Feeney
1970 911 T
1973 911 T
Old 10-26-2014, 01:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
This is a great post! I maybe purchasing a 81' this weekend, the owner mentioned a knock, so not sure what is wrong but know it'll have to be cheap if engine work is needed. Thanks!
Old 10-28-2014, 07:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
Crank
Crank was polished by Jim at JB Racing today. Miked it and said it looked excellent. A quick polish and it is ready to go. Lots of work still to do. Crank needs to be cleaned, plastigage the mains then rods and it should be ready for at least the short block assembly.
Tom Feeney
1970 911 T
1973 911 T
Old 10-28-2014, 04:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Time to check with plastigage
Installed all of the bearings and checked crank clearance with plastigage. All mains checked in right around 3 thousandths.
Next will be checking the rods to the crank. Still haven't figured out how to hold the rod still while tightening the bolt.
Tom Feeney
1970 911 T
1973 911 T
Old 11-02-2014, 03:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Gordo2's Avatar
Plastigage Rod Clearances
Originally Posted by Amstaff View Post
...Still haven't figured out how to hold the rod still while tightening the bolt.
Here's how I went about it Checking Connecting Rod Bearing Clearances With Plastigage
Looking good.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 11-02-2014, 08:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Thanks Gordon. I am going to attack it tomorrow evening
Tom Feeney
1970 911 T
1973 911 T
Old 11-04-2014, 04:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Well, planned on checking rods to crank tonight but guess what? No 12 point 13mm socket. Off to HF tomorrow!
Tom Feeney
1970 911 T
1973 911 T
Old 11-05-2014, 04:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
toddu's Avatar
Great guys at JB Racing!!
Todd
'81 SC
Old 11-05-2014, 04:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
Got the 12 mm socket and ready to go but guess what? The rod bearings were the wrong size. They will be sent back Monday for replacement.
I guess this is where the patience part comes in.
Patience grasshopper
Tom Feeney
1970 911 T
1973 911 T
Old 11-08-2014, 06:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Rods to crank
Started with the bottom one working my way up
Tom Feeney
1970 911 T
1973 911 T
Old 11-15-2014, 01:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
Rods
Checked them all with a stretch gauge but it worked horribly wobbling all over and it wouldn't stay on without holding it so I dropped back and punted using the torque method. Burnished the threads by torquing them three time. I also used the ARP lube.
Tom Feeney
1970 911 T
1973 911 T
Old 11-15-2014, 01:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Rods to crank
So, got them all installed. Next step... Short block assembly.
Made sure all of the rod numbers were matched correctly and that they were all on the same side.
Tom Feeney
1970 911 T
1973 911 T
Old 11-15-2014, 01:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
