Bagged
So, I went out and purchased one of those expensive engine bags to protect it and keep it clean.
I think Hefty makes them 😉 http://forums.pelicanparts.com/uploa...1417372836.jpg |
Nice tread and good job !!!
Back at it
Well, finally getting back to it. Head studs came in yesterday and a new Wrightwood head gasket set is on order. I heard too much bad stuff about other gaskets and want to do all I can to avoid leaks.
These head studs are a work of art! http://forums.pelicanparts.com/uploa...1422047028.jpg http://forums.pelicanparts.com/uploa...1422047054.jpg |
Great thread!!!!!!!!!
Keep up the good work and the updates coming. Love the high value engine bag :-) |
ARP Head Studs
Well, today the head studs went in. Look at a lot of links on installing them and decided to use a dab of locktite on them. Make sure that you don't overdo it, just a dab near the bottom of the threads will distribute it evenly.
Because of the thread chaser I made (see earlier post) the studs went right in by hand right to the bottom of the hole. Once the Locktite was on I screwed them in all the way to the bottom and then backed them out about 1/4 turn so that they weren't sitting on the bottom of the hole. Once in I used my caliper to make sure they were all fairly even which they were. Just a small turn her and there. http://forums.pelicanparts.com/uploa...1422111832.jpg http://forums.pelicanparts.com/uploa...1422111847.jpg Gasket set should be here Monday so look for piston and cylinder install next week. Still need to send the heads and cam tower for rebuilding. |
Locktite
Important!
One important thing that I should have posted before locktiting the stud in.
TRIAL FIT THE CYLINDERS AND HEADS TO MAKE SURE THAT THE STUDS PROTRUDE ENOUGH TO GET WASHERS AND NUTS ON! http://forums.pelicanparts.com/uploa...1422141809.jpg http://forums.pelicanparts.com/uploa...1422141895.jpg |
Nice job !!
Thanks for sharing........ |
Great thread!
Thanks for this great thread. I'm now a subscriber. Just picked up my new project a week or so ago. Yup, broken head studs. This thread will be an invaluable tool for my future endeavors! Keep up the great posts and pics!
http://forums.pelicanparts.com/uploa...1422279163.jpg http://forums.pelicanparts.com/uploa...1422279200.jpg |
Subbed. Awesome thread!
Great read and reference for those of us considering an engine rebuild someday! Thanks!
Heads and cam towers are boxed and ready for pickup by FedEx tomorrow. I sent them to Ollies. Called and spoke to them today, they said box them all up, put a note in the box explaining what I want done along with contact information and they would call once they get everything and can unpack and examine what I have.
Gasket set should be here tomorrow so I am inching closer to finishing! |
Cylinder holders
Saw cylinder holder tools available but when you only use it once why buy expensive tools? I bought a 2 foot piece of 1/2" PVC and made my own. Cut it with my pipe cutting tool to 1 1/2" and it fit perfect.
http://forums.pelicanparts.com/uploa...1424652271.jpg http://forums.pelicanparts.com/uploa...1424652296.jpg http://forums.pelicanparts.com/uploa...1424652331.jpg |
Parts will be back from Ollies tomorrow so look for updates soon.
I thought you couldn't hone alusil cylinders??
Honing Cylinders
Technically I didn't hone mine. After doing a lot of research I decided to clean them, and then use scotch bright on them. If you search this site you will see a lot of different ways to scuff the cylinders to reuse them. Mine was a low mileage engine and honestly, I didn't have $4000+ to sink into new Pistons and Cylinders so I reused what I had.
I have a 3.0sc with 100,000 on it and I'm wondering what I'm gonna do when I cross that bridge because honestly I don't have $4000 for new ones either. It seems crazy that one piston and one cylinder has to cost $500 or $600 dollars.
For a lot of Porsche guys money is no option. To me it is and I can't just drop 20 grand to build a killer motor so I am building mine on a budget. Honestly I don't have a budget but I am buying parts as I can afford it. I took a 3 month break over the holidays but am back at it. I think all of the big expenses are behind me now.
Had I tried to save the money to buy new Pistons and cylinders along with the extra cash it would have taken for additional machine shop work it would have been a 3 year build. |
Parts are here!
Cylinder install
Got the block ready to receive the piston and cylinder
http://forums.pelicanparts.com/uploa...1424735071.jpg |
| All times are GMT -8. The time now is 06:05 PM. |
