-   -   Rookie 3.0 rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/817029-rookie-3-0-rebuild.html)
Amstaff 09-05-2014 04:17 PM
Bad spot in case
I have seen this defect several times in this forum. My understanding is that it should not leak but to be positive clean it thoroughly with a small wire brush then clean it with brake cleaner, let it dry and then apply a smooth coating of JB Weld. That seems to be the fix that everyone recommends so I don't see there being an issue with it coming off.
Amstaff 09-13-2014 12:14 PM
Cleaning head stud threads
Well, today I cleaned the head stud threads. I took an old head stud, cut some slots in it to catch the nasty stuff in the threads.
http://forums.pelicanparts.com/uploa...1410635500.jpg
Then I squared off the other end to fit it into the handle for my tap.
http://forums.pelicanparts.com/uploa...1410635567.jpg
http://forums.pelicanparts.com/uploa...1410635588.jpg
It worked perfect!
GT2BH 09-14-2014 03:23 AM
Nice method, I'm going to borrow it ;)
Did a lot of bad stuff come out?
Amstaff 09-14-2014 04:32 AM
Head stud threads
Sure did, lots of junk came out of the hole. As you run the "tap" down the hole you break up all the old Locktite. Some metal came out but it was mostly Locktite.
rennch 09-20-2014 04:52 PM
Great thread. I'd like to do one someday.
Amstaff 10-17-2014 03:45 PM
Still at it
I know I am really slow but one thing I have learned is that building the engine takes time and you really need to be patient. Everything is ready to go to get the short block together. I just need to have the crank polished and I am ready to put the case back together.
I recently got a pair of 964 cams, plastigage and more sealant.
Hope to get an update soon with the short block going together.
http://forums.pelicanparts.com/uploa...1413585909.jpg
Amstaff 10-25-2014 04:51 PM
More goodies are here. New chain ramps and although I have already installed the old rings I have decided to attempt to hone my cylinders and install new rings. My crank goes to JB Racing Tuesday for polishing so I should be assembling the short block next weekend.
Amstaff 10-25-2014 05:45 PM
Parts
http://forums.pelicanparts.com/uploa...1414284276.jpg
Amstaff 10-26-2014 01:51 PM
Oil pump and chain rails
Installed the oil pump today. Also installed the two chain rails on the right hand side of the block. Long side goes toward the gears and the lonely brown ramp goes on the bottom right hand side nearest to the crankshaft. I opted to mark my bolts with a dab of red paint so that I know which bolts are torqued and which are not.
http://forums.pelicanparts.com/uploa...1414356530.jpg
http://forums.pelicanparts.com/uploa...1414356584.jpg
http://forums.pelicanparts.com/uploa...1414356668.jpg
Hope installing the pump doesn't interfere with plastigaging the crank.
robbieracer 10-28-2014 07:49 AM
This is a great post! I maybe purchasing a 81' this weekend, the owner mentioned a knock, so not sure what is wrong but know it'll have to be cheap if engine work is needed. Thanks!
Amstaff 10-28-2014 04:00 PM
Crank
Crank was polished by Jim at JB Racing today. Miked it and said it looked excellent. A quick polish and it is ready to go. Lots of work still to do. Crank needs to be cleaned, plastigage the mains then rods and it should be ready for at least the short block assembly.
http://forums.pelicanparts.com/uploa...1414537235.jpg
Amstaff 11-02-2014 03:14 PM
Time to check with plastigage
Installed all of the bearings and checked crank clearance with plastigage. All mains checked in right around 3 thousandths.
Next will be checking the rods to the crank. Still haven't figured out how to hold the rod still while tightening the bolt.
http://forums.pelicanparts.com/uploa...1414969930.jpg
http://forums.pelicanparts.com/uploa...1414969961.jpg
http://forums.pelicanparts.com/uploa...1414970003.jpg
http://forums.pelicanparts.com/uploa...1414970031.jpg
http://forums.pelicanparts.com/uploa...1414970056.jpg
Gordo2 11-02-2014 08:03 PM
Plastigage Rod Clearances
Originally Posted by Amstaff (Post 8335370)
...Still haven't figured out how to hold the rod still while tightening the bolt.
Here's how I went about it http://forums.pelicanparts.com/911-engine-rebuilding-forum/788681-checking-connecting-rod-bearing-clearances-plastigage.html
Looking good.
Gordo
Amstaff 11-04-2014 04:36 AM
Thanks Gordon. I am going to attack it tomorrow evening
Amstaff 11-05-2014 04:14 PM
Well, planned on checking rods to crank tonight but guess what? No 12 point 13mm socket. Off to HF tomorrow!
toddu 11-05-2014 04:47 PM
Great guys at JB Racing!!
Todd
Amstaff 11-08-2014 06:38 PM
Got the 12 mm socket and ready to go but guess what? The rod bearings were the wrong size. They will be sent back Monday for replacement.
I guess this is where the patience part comes in.
Patience grasshopper
Amstaff 11-15-2014 01:28 PM
Rods to crank
Started with the bottom one working my way up
http://forums.pelicanparts.com/uploa...1416086882.jpg
Amstaff 11-15-2014 01:35 PM
Rods
Checked them all with a stretch gauge but it worked horribly wobbling all over and it wouldn't stay on without holding it so I dropped back and punted using the torque method. Burnished the threads by torquing them three time. I also used the ARP lube.
http://forums.pelicanparts.com/uploa...1416087303.jpg
Amstaff 11-15-2014 01:39 PM
Rods to crank
So, got them all installed. Next step... Short block assembly.http://forums.pelicanparts.com/uploa...1416087447.jpg
Made sure all of the rod numbers were matched correctly and that they were all on the same side.
