It's a trap...
#6 con rod internal interference (oil pump)?? PICS
Hi y'all. #6 con rod does not move all the way across the spigot. The lower bearing cap is hitting on the oil pump. I can see that in the pics the wrist pin bushing is past the centerline of the motor, but I want to know for sure if this is normal. Thanks in advance.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
Unless you changed to a very large oil pump the clearance On the 4 web pump should be good. You do have to keep the rod on the horizontal.
Bruce |
It's a trap...
Thanks. I have and am using the stock pump that came out.
Cheers.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). Last edited by Speed Buggy; 06-18-2014 at 08:02 PM.. |
What about the level of corrosion on the upper head studs? Is that worrisome?
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
It's a trap...
If yous think these should be replaced, let me know. I am ordering new exhaust studs so I will be able to get them at the same time. The threads look good on the studs. Cheers.
Schleprock
The upper head studs are steel and pretty much never break. Many many people who have done top ends and full rebuilds have replaced only the lower dilavar studs (with steel) and the original upper studs still remain fine.
Kevin L '86 Carrera "Larry" |
It's a trap...
Cool...they stay.
E-85 sippin drunk
I Had to clearance two or three spots on my oil pump when I stroked the crank. It wasnt much, but it had to be done... nothing to it...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
It will bind... back the crank off a little and wiggle the rod as you move forward and it should clear just fine. Hopefully you have seen the "rubber band trick," give it a try.
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
