ganun's Avatar
Cam housing on an 87
While doing a valve adjustment today I noticed the cam housing part numbers start with 964, is this correct for an 87 3.2????
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 08-23-2014, 08:08 PM
The Dude abides...
bigel's Avatar
Not on my '87...starts with '930'.
'03 Carrera 4S
Old 08-24-2014, 04:13 AM
Yes the change was in about that time. The only difference in 88 and 90 is the drill for the studs from 8mm to 6 mm.
In the SC there was a 901 carrier with 4 bearing for the first couple years.
There was Carrera cases used in the late SC s'
Bruce
Old 08-24-2014, 04:42 AM
Bruce
Old 08-24-2014, 04:43 AM
ganun's Avatar
Thanks, what's the difference between the two, 930 and 964 housings.
Old 08-24-2014, 05:06 AM
The size of the cover studs.
Bruce
Old 08-24-2014, 01:07 PM
DSPTurtle's Avatar
6mm or 8mm studs in the cam carrier. Your valve covers should have the correct size hole. Only matters when you're ordering washers and locknuts. Lol
Old 08-24-2014, 02:44 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Porsche started using the 964 casting in '89 when they were producing both the '89 C4 (964 chassis) and the '89 Carrera 3.2
You can use 964 housings from a later model. It's the 930 (aka 965) cam housing for the 3.3 and 3.6 turbo engines. These cam housings are basically the same as the 3.2 cam housing. I have a pair of 964 turbo castings I bought used to replace the wasted housings on my '79 engine.
Kevin L
'86 Carrera "Larry"
Old 08-25-2014, 09:19 AM
I just did an 88 this year with 964 part number.
8mm studs for the Carrera
Bruce
Old 08-25-2014, 10:51 AM
