re-do ?
Hi everyone, when I installed my headstuds (arp) I couldn't find the special arp lube,so I used new motor oil mixed with some moly.torqued to 36ft.lbs. Of course I found the packet of lube 2 months later.In the meantime I've learned 36lbs. is considered by some experts on this board to be too high for a mag.case with case savers.Should I go back and re-torque the studs to around 25 lbs. with the arp lube? Any and all thoughts appreciated! thank you, T.C.
Pull them out clean them and redo,you will sleep better .
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Air Medal or two
I would with check with a few more experts .You have inserts right?
I know i went more then 25 on mine , never a problem. It seems like 35 was the number.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Kartoffelkopf
Can't offer any advice w.r.t. your mag case, but I'm with porschetub, insomuch that you;re asking the question, therefore you know deep-down you want to re-do them (
) ...been there, bought and wearing the damn t-shirt....I'd remove them, clean thoroughly and re-do to whatever is the correct spec.....and sleep easyRgds Mr OCD
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
Use the suggested lube on the threads if not previously applied. Sherwood Last edited by 911pcars; 08-19-2014 at 05:19 PM.. |
Kartoffelkopf
With regards to why remove and replace (R&R?) stuff, the ARP lube could/will torque differently to engine oil when tightening the head nuts. No good just backing-off something and re-torquing when you've got the wrong lube applied. Again, without investigating, I'm not aware what the procedure is with Mag cases and stud installation, but would've thought their heights need to be set before assembling everything, same as ally cases.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject Last edited by Spenny_b; 08-20-2014 at 06:02 AM.. |
Sherwood |
Do it right from the start because the mistakes made earlier on will cost you,its not like you are rebuilding an simple motor afterall.
Kartoffelkopf
Not to belabor this, but some owners tend to accept suggestions to the letter, and while I'm pretty certain you understand the difference between studs, bolts and nuts, I'm not sure interchanging terms makes it clearer to those who might be doing this for the first time and often without credible reference materials to follow (the assemble-by-numbers approach).
So, when it was suggested to, "Pull them out clean them and redo, you will sleep better", I wanted to clarify that removing the cyl. head studs ("pull them out") isn't necessary just to re-apply the suggested torque lube. The only torque applied to the head stud is to the end clamping the cylinder head in place with its threaded nut, and where a quick spritz and dry with a spray solvent is probably sufficient to prep the threads for the proper torque lube instead of potentially removing (6) piston/cylinder assemblies, (6) heads and (24) cyl. head studs. Apologies. Color me anal-retentive as it relates to using the correct terms. It's an occupational habit. |
Porsche's Love-em Live-em
I would never torque the cly. head nuts to more then 24lb's on a mag case! regardless of type of stud. EVEN with 2ed over size case savers/time serts. They can pull. On a 2.7ltr. mag case it would be advisable to under torque a little then ever over torque. I use a little[any] lubricant except anti size on the threads of the nuts.
If yours haven't puled the case savers loose yet I would back off, re torque AND count your blessings. |
